6000 series comfy cab? (Heat houser)
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Topic: 6000 series comfy cab? (Heat houser)
    Posted: 22 Jan 2019 at 6:47am
Does any one have one that they use? I would like to buy one but not sure about the universal fit ones. Any information on them and or reviews would be great. Thanks
Edited by allis6080 - 23 Jan 2019 at 6:38am
6060 s\n 5016
1947 JD B
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 4:17pm
Factory cab is much better than any universal fit one!
fourthgeneration View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourthgeneration Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 8:03pm
Have you checked with Heitmans? Also join the big Allis Chalmers Facebook groups. Ask if anyone is parting out a tractor. And tell them what you are looking for.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 8:20pm
I’ve heard putting a factory cab on a non cab tractor is a pain.
My first 6080 had a aftermarket cab removed the cab and put a canopy on it.
I HATE AFTERMARKET CABS with a passion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 6:06am
Well I'm more or less looking for something like a heat houser. I can't afford a solid cab something I can take off in the summer and put on in the winter to block snow and wind in the winter thanks
6060 s\n 5016
1947 JD B
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 10:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 12:29pm
Originally posted by Alberta Phil Alberta Phil wrote:
Something like this.
Yep exactly what I'm leaning towards. Just wondering if any one had any luck with them.
6060 s\n 5016
1947 JD B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 6:41pm
Oh yeah those work good , had one on a 5600 Ford back in the big farm days ,, utilizes the engine heat very well
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 7:25pm
I have a couple AC heathousers for a 6080. Not sure how it breaks down to ship, wish you were closer l would sell one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2019 at 5:01am
That's the way it always goes. Thanks though.
6060 s\n 5016
1947 JD B
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 12:55am
If you can't find a heathouser, one option is to buy a canvas, cut some holes for muffler, etc and drape it down the sides to hold the engine heat in.  Tie the bottom together.  It won't block the snow, but it will funnel heat back to the operator.  I used to do this when I had the snowblower on a 185.
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 3:50am
We have a heat house for our open station 6080. Dad put it on a few times as a kid. Problem was that engine did not produce near the heat running around the yard feeding calves as the 180 and D17 gas tractors that it replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 9:47am
That maybe what I end up doing not sure if I want to spent that kind of money on something that is not going to be a perfect fit.
6060 s\n 5016
1947 JD B
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 2:56pm
IG where in Illinois are you and how much would you want for a 6080 heathouser. I'm in central iowa.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2019 at 1:11pm
Femco and Heat Houser brand are usually near perfect fit. I'd honestly spend the extra money on the Heat Houser brand. They have the better product, it's still the heavy green canvas. It holds up a lot better than the vinyl Femco uses. Give them a call.
http://www.burchmfg.com/ag_heat_houser/allischalmers.htm
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
