8050 shifting problem
uptegr74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uptegr74 Quote  Post ReplyReply Direct Link To This Post Topic: 8050 shifting problem
    Posted: 20 Jan 2019 at 10:45pm
We have an 8050 Allis that won't shift on the high/low/park lever. It was stuck in neutral, so I pulled it home. I have the seat and floor plates out. Both cables function fine, but with cables disconnected I can't move the shifter sticking out the top of the transmission. Any guidance would be greatly appreciated. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 11:37pm
Welcome to the forum, there's some good info on here, someone will help you.
What other allis stuff you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote uptegr74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:10am
We have a 7020, 7030, 7040 and two 8050s.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 7:18am
I am not sure what to tell you about the shifter problem, but someone on here will be able to. But, welcome to the forum, and you have quite the respectable line up of AC tractors. Are they all daily users in a farm/ranch operation.. ? Darrel
Post Options Post Options   Thanks (1) Thanks(1)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 8:36am
Sounds like it didn't come all the way out of one range. Remove snapring holding shifter in and look down in hole. Notches may not be lined up. If not, use a long screwdriver to line them up.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote uptegr74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 9:21am
Thanks. A couple get daily use for choring. The rest come out during hay season.
Edited by uptegr74 - 21 Jan 2019 at 11:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote uptegr74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 9:27am
Thanks Mack. I was able to gently persuade it into high and low with a mallet. It's just to stiff for the cable to shift it. Is the snapring under the rubber boot?
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 9:40am
yes it is under the boot .  I have seen cables worn to the point that you can't shift them at all. you may want to check that out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 10:25pm
Well hope you stick around after you get it fixed
Post Options Post Options   Thanks (0) Thanks(0)   Quote uptegr74 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 11:49pm
Well with my day job I haven't got it fixed yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote uptegr74 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2019 at 1:32pm
Finally got the snap ring in the shifter pulled up out of the transmission. Nothing looks out of place. Does anyone know what my problem with not being able to shift into high low would be?
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2019 at 2:50pm
Are you sure the side to side cable is moving the lever into the high-low slot completely?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2019 at 3:07pm
I think in this case, you need to clean off all the dirt around the cover to the range transmission and remove it for a look see. You should be able to get in there with a pry bar and shift the fork completely forwards and backwards remembering that the shifting dogs have to line up on the gears to complete the shifting of the coupling/collar. There could be something wrong with the shifting rails, which would hinder fork movement. I can't say I've ever had one do as you are describing. I've replaced lots of worn out shift lugs for PARK position and the interlock pin and that's about it. Remember, just because the shift cable moves in and out unhooked, doesn't mean it can do that under a load......i.e. move a shift lever and fork.
Edited by DrAllis - 27 Jan 2019 at 3:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote uptegr74 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 1:35pm
Thanks for all your input. I pulled plate off top of tranny and I have alot of chipped teeth, so we're splitting the tractor.
This page was generated in 2.263 seconds.
