6070 thrust bearing beefed up?? |
rieg
Topic: 6070 thrust bearing beefed up??Posted: 19 Jan 2019 at 9:40pm |
When you guys refer to the thrust bearing being beefed up in the later models are you talking about the number four main crank shaft bearing and thrust washer combo? I am doing and in frame overhaul using a Reliance kit recommended by my AGCO dealer. The number four main and thrust bearing that is in the kit does not look to be the same as what I removed it has a lot less surface area for the side to side thrust part of it. When I ordered the kit I told them I had the later engine and gave them the serial number which they said didn't mean anything to them. I can't find anything on the AGCO parts book that helps me out. If any body can explain this to me I would be most grateful.
rieg
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 19 Jan 2019 at 10:02pm |
Don't know the particulars but yes.What has been said here before is that the latest ones had a larger surface area thrust brg.Sounds like that's what yours is.Sounds like what you got is the earlier style.
rieg
Posted: 20 Jan 2019 at 10:05am |
Thanks Steve does anyone know the engine serial number break or tractor serial number or do all 6070s have the heaver thrust bearing?
rieg
DougG
Posted: 20 Jan 2019 at 12:24pm |
Pretty sure the 6070,s should have it as they were last production and I remember seeing a bulliten as of mid 83 they redone the blocks
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 20 Jan 2019 at 6:23pm |
rieg
Posted: 20 Jan 2019 at 10:07pm |
Thanks so much guys looks like Reliance sent the wrong thrust bearing my tractor should have the updated one. I hope they will rectify this problem. Once again you guys are amazing Thanks again.
rieg
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 21 Jan 2019 at 7:05am |
Take your bearings ( old ones also ) along back to where you bought them .Have them check sizes. Then have them look them back up under reliance . Reliance is not the problem.
Mikez
Posted: 21 Jan 2019 at 8:57am |
I thought awhile back I read on here that when you order from agco you get the updated version and whenever you order aftermarket company's they come in the old style. I know this sounds crazy but when I ordered for my 6080 and mine is the old style, I got agco bearings and they came in the updated style. Then I came on here and was told that and ordered from aftermarket and sure enough it was the old style. Try it from agco
Like I said sounds crazy, Edited by Mikez - 21 Jan 2019 at 8:58am |
