need drive sheave |
Post Reply ![]() |
DanNESD ![]() Silver Level ![]() ![]() Joined: 22 Oct 2009 Location: Milbank, SD Points: 182 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Jul 2010 at 1:04pm |
I need the drive sheave assembly for a #5 mower going on a B (part # 70802145) if I can't find the complete sheave the hub (part # 70802147) would help in making one myself. I need one for an 1 1/8 PTO shaft. Any help will be greatly appreciated, Thanks in advance!
Dan
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1469 |
This the one your needing? Dale |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
If you can't find an original AC one I would think a 2 piece Browning would work. There is a split taper bushing thats 1 1/8" dia. If I knew what size the pulley is, both diameter and belt width, I look to see it there's a pulley that would work with the 1 1/8" bushing.
Dusty
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
A number 5 would use a drive sheave with two grooves, and the Outside Diameter would be a little smaller too...
The picture Dale posted is the one I need. Do you know where I can get one? The belt is still available through Agco.
Dan....This is what I have. Thanks....Dale
norm [ind] ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
all the pulleys i have ever seen have been the 1 1/8 '' size have one in the barn
Post Reply ![]() |
