440 motor
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: 440 motor
    Posted: 14 Jan 2019 at 3:04pm
What would be a good replacement 440 motor for the 555 besides a 555 1st motor broke crankshaft it was repaired broke another then they replaced with different 555 that one weent about 200 hrs crank broke between 1st and 2nd main and that's how we got it thinking about a 444e out of a bus and turn the power down
Edited by bradley6874 - 14 Jan 2019 at 3:05pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 5:23pm
Why did these engines perform so poorly in these tractors?
What did the Steiger tractors use?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 6:31pm
google triple nickel cummins    ///   'and....  seems they did well in large boats....trying to say something positive...
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 7:31pm
According to Tractor Data, the Steiger Bearcat, had a Cat 3160. I would think you could put in 3160, or a 3208.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 9:00pm
Creston from what I have found out they were not balanced to turn 3000 rpm and basically shook apart
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 9:58pm
They have a SAE bell housing so most any industrial motor will work. The 3208 would not be my choice.      MACK
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 11:38pm
I have a 6v92 that’s going to be going in mine. I like a 3208, but I would look for a 3208t with the 3 ring pistons if you go that route. Been good motors in trucks for us, but 335hp with the 2 stroke and there tough as nails.
Edited by 7060 - 14 Jan 2019 at 11:38pm
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 11:56pm
Is it turboed and did the crankshaft get turned down at all?
Have a v504 in our versatile and it’s been a tough little engine.
Heard if you grind the cranks at all they will break easier in the 555 and that the 555 liked to break cranks when turboed. I would maybe look at a IH 466 truck engine. Bell housing looks similar and the 466 is tough as nails, and the truck engines are cheap and dime a dozen.
I also do like the 444e idea. Would be cool and they are indestructible. Reliable power. Not sure how you would turn it down being it’s computerized, but I think our ih 4700 is only rated at 210 I think, might even be 190, would hold up to that just fine I would think it you treated it correctly.
Edited by Carl(NWWI) - 15 Jan 2019 at 12:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 10:04am
International dealer can turn it down with their computers told me after find the plug under the dash and pull that harness out and plug it in and then they can set it for whatever horsepower we want RPMs we want if you go much above what it was originally horsepower wise Dropbox is probably the next week is link
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 5:15pm
I like the 6V92 idea. They also have low end torque.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 6:40pm
Mack, just curious, what didn't you like about the 3208?
Bradleytrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 7:18pm
Why not a Cummins BTA 5.9??
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 7:50pm
May be worth considering the rpms of the 555 vs the operating rpms of a replacement motor. I think the 555 ran pretty high rpms so any difference may really change the transmission speeds
Orange & Silver still earnin their keep on the farm: R62, Series IV D17 nf, 185, 6080, 6080 fwa, 220, 1968 D21, 7045, DT240.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 8:05pm
That 555 Cummins was rated at 218 flywheel HP @ 2800 RPM, so high idle was probably 2900 to 3000 RPM's no load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 9:20pm
444e rated 210 hp is 215hp at 2400 governor is set at 2800
Edited by bradley6874 - 15 Jan 2019 at 9:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 10:03pm
The 3208 I had started as soon as you hit the starter but when it saw a hill it would start slowing down. No balls.     MACK
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 10:08pm
3306 and youd make a hell of a tractor!
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 1:04am
A Dogtroit with low end torque, now that’s a fantasy 😸
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 7:02am
I don't know much about engine conversions but why not an engine out of an N7. The 516 in our dozer is fuel efficient and one of the best starting Allis engines I've ever been around.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 7:04am
I'd guess the 516 is physically too long to fit where a 555 was.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 9:54am
I actually bought a 3306 to put in mine and to go with a 6cylinder in-line you would almost have to stretch the frame 10”. It would fit if you could scoot the transmission back a little, but the driveshaft is already almost too short. That’s no big deal, but I didn’t like the way it would look. I bought a 6v92 out of a semi for $500 and figured with 100 extra horsepower you wouldn’t notice the low end torque as much, but the 555 or 3208 don’t really have any either. The 555 isn’t exactly quiet and with the turbo and a set of resonators I don’t think the 6v92 will be bad on noise. Got to be better than driving the cabover it came out of.
Edited by 7060 - 16 Jan 2019 at 9:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 9:54am
Two things wrong with the 516 length and rpm don't think the 516 would like 3,000 RPMs very well
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 10:12am
Yikes! I guess not then
Wink
I am a Russian Bot
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 1:20pm
IN my two 440's, I NEVER ran more than 21 or 22 hundred!--- never had a problem. Mine will tach at 3,300 IF ya don't watch them! --- NO way I would ever run one that hard!  You can tell at 22 hundred that everything is smooth, engine purrin' along and not boggin' down, so that's were mine run!
I would go for the Detroit if re-power was needed! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 3:11pm
So Paul,you ever been around the turboed 92 series? Don't appear so.
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 6:05pm
Everyone dogs a 3208 but in reality they are a small engine that was slways overworked in big trucks. 3208's are excellent in medium duty trucks.
In a stieger bearcat 2 they made 225hp.
Steiger didnt regear the high rpm v8 tractors. Thats why our bear cat will run 30+ mph down the road
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 6:48pm
I had a 3208 in a Cat 225 excavator chasis with a 50 foot delimber boom mounted on it (logging)  When I sold the machine it had 12000 hrs on it, I did have the Cat shop pull one head for a antifreeze leak and do injectors at about 8k hr's.   It was easy work for it on the delimber but anyway I was very pleased with it's service.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 7:09pm
We had a 3160, and a 3208 in Field Queen choppers, I always thought they were good luggers, but they were always run at full throttle. Truck application might be quite different.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2019 at 7:45pm
I had a 6V92 at 335 hp and a Formula 290 Cummins both in 78 Ford heavy tandam straights. The 6V92 would lug just as good as the 290 and actually had a lower RPM point for a down shift. Now my 3208 in a Ford single axle wouldn't pull a hen off a nest. I've seen a 6V71 in a 440.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 3:39am
Steve: just the idea that you think a 2cycle like the 6V92 or if you want a do-over even the 6v92T can have low end torque is halarious and tells me you are easily impressed. I have been driving trucks for the past 45 years now and just the fact that most all of the 2 cycle Dogtriots were mated to 13 speeds or more whereas an engine with GENUINE torque may only have a 9 or 10 has a lot to say. How about those 300+ Macks with a 5 speed, now that’s torque. I have also operated many FieldQueens with the 6v92 and it is a good engine within it’s capabilities and running at top governed RPM. However any 2cycle will fall faster than a barrel over a waterfall when it sees a hill. The only time you can let up on a Dogtriot is when you need to downshift, then it’s right back on the floor. I have driven many large CID gas engines back in the day that could be considered to have torque, such as a Hall-Scott big Walkashaw and even those V12 GMCs , they where fun with the 5X4 and for their time impressive.
   Now the idea of replacing a 555 rated at around 200HP with any engine of 300 or so is just asking for drivetrain issues. If you want to suggest a 2cycle to replace rge 555 just so you can listen to that annoying 2cycle wine, a 6v53 or derated 6v71 would be more suitable.
