AC wheels on a JD 435
CaseyCreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CaseyCreek Quote  Post ReplyReply Direct Link To This Post Topic: AC wheels on a JD 435
    Posted: 09 Jan 2019 at 7:32pm
The local paper did an article on how one of the high school's has a program to restore old tractors.  The picture below was the main picture for the article.  I thought that the wheels looked oddly familiar:
Was this original equipment or did someone in the past do an AC upgrade on this tractor?  If any of you guys know the backstory, I would like to read about it.
D17 Series III,D17 Series IV, 185
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:35pm
Deere offered power adjust wheels for that tractor. Either after the patent ran out or they paid Allis a royalty as some other companies did back then.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:59pm
That wheel center is not like AC's. Also looks to have the screw on the slide bracket to tighten .
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:08pm
I have seen a setup like this on a Farmall but don't remember the size.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 8:33pm
Oliver used the same power adjust wheel center.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 6:46am
Ford used the same center also.
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 7:50am
years back, my mechanic was working on an old john deere backhoe about the size of that tractor and it had 24 inch wheels on it, it set to low to the ground and would drag and get high centered, I had a tractor in the shop at same time, he got to studying on the bolt pattern and figured they would fit. I found him  a set of tires and wheels off another allis tractor and we put them on it for clearance.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 8:04am
My 1958 420 had power adjust wheels/rims on it.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 8:39am
The IH version doesn't hold worth a dime.
Wink
I am a Russian Bot
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 9:24am
The JD wheels have a different clamp. Those power adjust wheels were not an Allis-made item they were an outside supplier contract, similar to the F&H wheels. Look in the current Unverferth catalog, they list all the rim clamp parts for their power adjust wheels and they look exactly like Allis.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 10:59am
Allis invented and patented the power adjust wheels and anyone building and selling anything like it before the patent ran out paid Allis Chalmers a royalty. That's the way I understand it.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 11:46am
They were invented and designed by Allis but the ones on the John Deere would have been an outside company by that time. All power shift wheels have been made by other companies for some time.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 4:39pm
Of course. How long do the patents last with something like that? Also I think the 420/520/620/720 were available with power adjusted wheels in 1956.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 5:41pm
Don't think its anywhere near the same.  IIRR, their's was a screw thread thingy, that freezes up real bad, if rusty or dirty...Wink
[TUBE]ZkJW8TDa7Ms[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 6:23pm
Look again, Dave
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 6:39pm
I have a WD that has a Ford rim on it. Its been too many years ago but I think the holes in the rail for wheel settings was different.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 6:02am
I believe those patents were good for 7 years and renewable for another 7 years. I would assume the first patent was issued in 1948 unless it was issued a few years before the WD came out.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 7:02am
Massey had PA wheels on some of their tractors pretty early.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 6:03pm
Look again, Dave
By that time, the patent prolly expired.  The vid I showed was the system ford had, on the hundred series tractors. 3000's didn't come out, or more accurately in, as they were brit imports, till 1965...Wink
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 7:59pm
Allis sold the patent to Goodyear after a few years.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:07pm
Patents last for 17 years and can be renewed with slight tweaking to the design.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 8:09am
I'd wager the 3000 pictured was built in Highland Park, MI.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 6:11pm
Depends on the prefix, could be here, britian or belgium...
Ford 3000
Ford 3000 tractor photo
1965 - 1975
Utility tractor
Next model:Ford 3600
The Ford 3000 would have an A (Belgium), B (England), or C (United States) prefix to the serial number depending on where it was built.
Production:
Manufacturer:Ford
Factory:Highland Park, Michigan, USA
 Basildon, England
 Antwerp, Belgium
Original price (USD)
   $6,300 (1975 )
Ford 3000 Engines:
   Ford 2.6L 3-cyl gasoline
   Ford 2.9L 3-cyl diesel
full engine details ...
Capacity:
Fuel:13 gal [49.2 L]
Hydraulic system:6.3 gal [23.8 L]
3-Point Hitch:
Rear Type:I
Rear lift (at 24"/610mm):1700 lbs [771 kg]
Power Take-off (PTO):
Rear PTO:transmission*
 live*
 independent*
Rear RPM:540
 540/1000*
Dimensions & Tires:
Wheelbase:75.8 inches [192 cm]
Weight:3700 to 4185 pounds
Front tire:5.50-16
Rear tire:12.4-28
full dimensions and tires ...
Ford 3000 attachments:
 front-end loader
all 3000 attachments ...
3000 Serial Numbers:
Location:Transmission, front upper-right corner, stamped into top of casting
photo of 3000 serial number
1965: C100000
1966: C124200
1967: C161300
1968: C190200
1969: C226000
1970: C257600
1971: C292100
1972: C327200
1973: C367300
1974: C405200
1975: C450700
how to read serial numbers...
Ford 3000 Power:
Engine:47 hp [35.0 kW]
Drawbar (claimed):33 hp [24.6 kW]
Diesel PTO (claimed):38 hp [28.3 kW]
Gasoline PTO (claimed):37 hp [27.6 kW]
Drawbar (tested):35.43 hp [26.4 kW]
PTO (tested):40.63 hp [30.3 kW]
power test details ...
Mechanical:
Chassis:4x2 2WD
Differential lock:mechanical rear*
Steering:manual
 power assist*
Brakes:mechanical expanding shoe
Cab:Open operator station. Canvas cab optional.
Hydraulics:
Type:open center
Capacity:6.3 gal [23.8 L]
Pressure:2500 psi [172.4 bar]
Pump flow:5 gpm [18.9 lpm]
Steering flow:4.25 gpm [16.1 lpm]
Steering press.:600 psi [41.4 bar]
Electrical:
Ground:negative
Charging system:generator
Charging amps:22
Battery:
Number:1
Volts:12
Gas Amp-hours:80
Diesel Amp-hours:128
Page information:
Last update:December 29, 2018
Copyright:Copyright 2019 TractorData LLC
Contact:Peter@TractorData.com
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 6:14pm
I was told once that Allis did not own the patent on that wheel design but it was a wheel company or tire company, I forget which, but Allis had exclusive rights to it.
Dusty
This page was generated in 0.177 seconds.
