Allis 200 SN 1803 Hydraulic PTO
smitty78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 200 SN 1803 Hydraulic PTO
    Posted: 06 Jan 2019 at 6:49pm
I've got my old 200 tractor in the shop for some maintenance on the starter, alternator, and pump-injector overhaul.  Currently hydraulic PTO not working at all so I want to look at that as well.  Shifter moves into the 3 positions fine.  Valve seemed a bit sticky so removed and working to fix that.
If it still won't work, what's the next debug step to try & get it working without a split ?
Thanks
Edited by smitty78 - 06 Jan 2019 at 8:38pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 9:24pm
It could be disconnected internally. Check between the battery box and the torque tube for a lever that might have moved.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 9:25pm
Make sure the manual shifter on the side of the housing behind the battery box is shifted so it couples the 2 shafts together inside
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 7:31am
Turn pto by hand. If it spins free, coupler has slid forward. If there is some drag you have other problems.
No need to split for most pto repairs. Drop pto box.    MACK
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 8:07am
check pressure to pto clutch center line at pto housing put gauge right line
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 8:19pm
Thanks so much for the information.  The pto does turn easily by hand and will check pressure.  I'll look for something behind the battery box even though my hydraulic pto doesn't have any linkage or lines going that way.  Verified all of the hydraulic lines go to and from the correct place.  Made my way through the PTO valve and found the control rod side prone to stick so polished it up.  On the other side found a chunk gashed out of the relief valve spool which made the plunger stick.  Didn't find the chunk.  It was hard to tell if the tiny orifice was plugged but it may have been.  Would this damage make the pto system completely unresponsive ?  Is this a salvage yard only part ?
Edited by smitty78 - 07 Jan 2019 at 8:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2019 at 9:07pm
If it spins free, coupler has slid off. Remove PD valve and plate. With a bar, reach through hole and slide it back on.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 3:53pm
Since the PTO valve damaged parts are mated to the parts, I got a valve outa salvage.  The one sent is the greater than SN 4001 version but perhaps it will work.  Strangely the caps were switched compared to my old valve.
Does anyone know if the cap with the notches (larger internal cavity) aligns with the control rod side or the relief valve spool side of the PTO valve ?  (See photo)
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 3:58pm
And, Mack, attached is a pic of the PTO shaft with the power shift valve and plate removed ... the shaft is disconnected from the coupler but I thought perhaps it was moved to engage when the PTO is engaged.  If not I should use a bar to slide the coupler onto the shaft correct ?  What makes it stay in that position ?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 4:13pm
Theres springs and balls that hold the coupler in one spot, the balls fall into detent holes that holds them
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 4:35pm
There is a short lever behind the front of the battery box. I can see it in the picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 4:39pm
And of course there is a metal strap with a hole in it, attached to a shaft between the battery box & housing.  Initially looks like an anchor point for something.  Doesn't look like an adjustable lever, no handle, nothing in my owners manual about it, no stickers or cast features to hint which direction engages or disengages, but it's there and it moves the coupler into engagement by rotating the hole in the strap toward the radiator.  Likely didn't need a new valve at all but live & learn.  I owe you guys coffee & pie, if only there was anywhere to get it anymore.
Edited by smitty78 - 26 Jan 2019 at 4:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 4:49pm
So now that some of this stuff is exposed, is there any opportunity to address the fluid movement between the powershift & hydraulic reservoirs ?
Maybe the new to me PTO valve will magically stop the transfer lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 5:19pm
If you are losing hydraulic oil (left dipstick when sitting in the seat) and gaining oil in the transmission/differential (right dipstick when sitting in the seat), the problem requires a split of the tractor at the area under the platform. No proper fix without a split.  There can be a homemade oil transfer hose installed to allow oil to level itself out between the two sumps. I assume two drain plugs are removed and a hose connects between them. Don't actually know as I've never done one that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitty78 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 9:50pm
Gotcha,  I have a little pump I use to transfer the overfull side back to the low side and don't have to do it very often so I'll keep doing that till I have to go in for some other reason.
1 other question though, anybody know how water gets into the hydraulic fluid on these 200's ?  Seems like if it sprinkles for 5 minutes the oil is 1/2 water.  I just flat have to put it inside even if it's only foggy.  Can't seem to figure out how it gets in, but of course I'm the same dude that didn't go look for that pto lever first thing, so my thinkin track record is not so hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 10:08pm
You must not have the platform cover over the dipsticks installed ??
