D14 Front crank seal
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D14 Front crank seal
    Posted: 27 Dec 2018 at 8:02pm
The crankshaft seal on my 58 D14 has been leaking for the last several years - finally getting around to fixing it.  Does the timing cover need to be removed to yank out the old one and put a new one in?  Just wondering if I need to order a timing cover gasket to go along with it.
Many thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 9:56pm
I would remove front plate just to center it on crankshaft.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 1:16am
To do it right, you will also need to remove the oil pan. This will allow you to get the front cover properly positioned without interference from the oil pan.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 2:42am
On a series II D15 I drilled a couple small holes in the seal 180 degrees apart, threaded in a metal screw and pulled the seal out. The old seal was a lot deeper than the new on I purchased from Maple Lane Farm  Equipment, Mount forest.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 5:38am
If you weant a 'practise' run, come on over, you can work out the details on 'Troy'. My garage is toasty warm.......
..maybe do the left diff seal as well, ?? Wink
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 9:12am
Jay
Toasty warm in here too with the oil furnace!  Plenty of ACs getting my attention:  Brakes and other little things on the 185, getting my freebee B110 running, and the D14.  That's a tempting offer you have though!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 9:20am
Jay is so accommodating, and he has a new roof too. Wink
