air planter plates
briannowak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briannowak Quote  Post ReplyReply Direct Link To This Post Topic: air planter plates
    Posted: 24 Jul 2010 at 1:12pm
I am considering a AC air champ planter (don't know and specific model number for the planter units) and was wondering how easy it is to find seed plates for it. As far as I could tell, the plates are about 10 inches in diameter and plastic (dark green maybe?). Any place these can be readily found?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 3:29pm
lustran.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 5:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote briannowak Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 8:29pm
I checked them out already, but from what I see on their website,  it looks like they produce plates that fit in the bottom of a seed hopper like you find on a JD 71 planter. The unit that I am looking at (AC "air champ") has the plate mounted vertically underneath the hopper and uses a fan to hold the seed in place.
andytutd21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andytutd21 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 9:31pm
I have several decent ones. I no longer use the planters, use the deutz Allis planter now. Saving the planters to make a copy of the Allis no-till drill they show in one of Norm's books. Looks like a planter frame with a All Crop drill on top of it.
1984 8070 ps fwa, 1969 D-21, 1965 D-21(puller), 1968 190 XT, WD-45, Gleaner L, I-40 loader, TS200 Pan, AD-3 Road Grader, 918 Backhoe, HD-4 6 way, HD-4 loader, HD-7G, HD-11, HD-21
Post Options Post Options   Thanks (0) Thanks(0)   Quote briannowak Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:53am
I'll buy some if you willing to part with them. you can contact me at 319 895 8338
brian
orange paint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange paint Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:38am
I thought the seed disc were a the same as used on newer DA planters?   Becarfull in buying used discs if worn thin then can be a problem.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 12:52pm
PROBABLY CAN FIX YOU UP  - bgtbran@hotmail.com
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:05pm
DA air plates are thinner at the hub but if you cut the part off that extends out from the gussets on the back side (side away from seed pockets) the older plates will work fine!
