Hammer Strap
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Topic: Hammer Strap
    Posted: 24 Jul 2010 at 3:16am
I wonder if this hammer strap would fit any orange drawbars?
http://cgi.ebay.com/Case-IH-Strap-Hammer-A-A61557-1090-1170-1175-1270-1370-/120532438531?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item1c104b0e03
I wouldn't mind adding a hammer strap to my 170.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 4:20am
If its not hardened thats a spendy piece of flat iron.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 8:22pm
If you are up to adding some more holes in your drawbar it will work.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 8:39pm
I don't want to add any more hole to my drawbar, it already has holes from the factory where a hammer strap would bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 8:59pm
Here's the pic of that hammerstrap on the 175D that became the 170....it has extra holes in the drawbar, so maybe it isn't original AC.....tires and rims now belong to Chuck Luedtke (sp?) in WI, fender are for sale....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 9:01pm
Those fenders look nice Eldon, keep them, hang them on the wall in the shed or one day you will be kicking yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 9:11pm
There is something weird with one of the fenders as it doesn't line up with the other...wouldn't notice it on the tractor, but it was obvious in my 4 tractor lineup. This fender was tilted forward. I posted this pic before with no reply...you can see the fender on the left the "dirt line" isn't parallel to the mouting holes....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 9:21pm
The fenders on my 170 had an Allis Chalmers heat houser mounted to them at one time, so there is extra holes in the tops of them.  It's not a huge deal but it annoys me.  Also when my Dad and I went and looked at the tractor the guy selling it had it used it for snowblowing.  The right fender is slightly bent, I always figured He must have had chains on the tires and something got hooked in them and went around the wheel to bend the fender, again not a big deal but I wish it was straight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 9:55pm
Both of these D21 have hammer straps, they both look the same so i believe they are Allis Chalmers made.  I wonder if they would fit my drawbar.
Edited by Claus - 24 Jul 2010 at 10:56pm
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 10:10pm
I've got to ask, what in the heck is a hammerstrap? My WDs gotten along just fine without one! LOL
mojo/Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 10:58pm
mojo/Mike
A hammer strap is a clevis hitch.  Notice the drawbar on Eldon's tractor or both of the D21s above.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 8:23am
Nice pics of the hammer straps. Most AC 4W305,s  have them on. My did not when I brought it but ordered from an old AC dealer. Its makes hitching to some on the bigger implements so you can hitch lower or higher. Or some not many have a single tongue.
Kurzy
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2010 at 9:16am
Some implements have a swivel ball hitch ( like the 3 point draft arm) and this is connected between the drawbar and hammerstrap top part,  but you need a good heavy washer for it to ride on or your drawbar will suffer.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:09am
You might consider doing some measuring and seeing if any of the 7000 series tractors have the same size drawbar.  I realized too late that I needed a hammer strap for my 7045 to pull a Great Plains No-Till drill that has a hitch like Kurzy described.  I couldnt find one when I advertised here looking for one, so I went with the heavy bolt with lock nut option (crude but effective) and got along fine.  I was able to locate one now, and look forward to having it on the tractor for next planting season. Good luck!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:16am
mojo/Mike
Thankyou, now I dont have to ask
LOL
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:24am
4W305 strap will fit one the 7000's and 8000's. The 7045 needs it for the sprayer & the 8070 needs it for the planter.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 1:13pm
"Typically, a hammer strap is mounted on a tractor drawbar, and a towed implement can be coupled to the drawbar with a drawbar or hammer strap pin which passes through the hammer strap and the drawbar. Preferably, such a hammer strap should havea low profile in order to accommodate power-take-off (PTO) operated equipment using the drawbar while operating over uneven terrain. A hammer strap which extends too high may contact the PTO. The drawbar pin should remain vertically fixed despitevertical movement of the implement and drawbar. The drawbar pin also must resist rotational movement so as not to cause excessive wear to the drawbar and/or hammer strap. The drawbar pin must be secured in it's working position. Finally, for customer convenience it would be desirable to provide a handle for the drawbar pin."
Ah, so it isn't that leather shoelace strung through the end of my EastWing rock pick.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 7:22pm
I think you will want for the 7000 and 8000 series a 70240504 strap. We have one around, but I do use it occasionally with a field cultivator. Just going by memory on the number, if I find out differently I will edit.
This page was generated in 0.262 seconds.
