allis chlmaers sickle mower
Daniels wc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniels wc Quote  Post ReplyReply Direct Link To This Post Topic: allis chlmaers sickle mower
    Posted: 01 Dec 2018 at 1:14pm
https://kirksville.craigslist.org/grd/d/allis-chalmers-sicklebar-mower/6741966084.html check this out dose any one know why this mower has the metal guides behind the cutting bar
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 2:19pm
I’ve seen similar setups used for making a windrow.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 2:46pm
Windrow
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 9:43pm
There were two types of windrowers.  One like this that made the hay into the center and there were those that windrowed the hay into one on the right.  Same type just different set of guides.
Good Luck!
Bill Long
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 9:06am
does anyone know what size tractor this was designed for?
or Model number of the mower?
Thanks, John.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 9:30am
It's a #3 and used on the W tractors new.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 9:36am
That's a #3 mower, 1951 or later.
There were brackets made to mount it to B, C, CA, WC and WD tractors.
I would think it could be easily adapted to about any make tractor.
It is interesting that it has both the wind rower bars as well as the pasture clipping wheel
out on the end of the bar.
Looks to be in decent shape.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 11:40am
Check to see if they have the mounts for it. The mounts are tractor specific.
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 3:10pm
Number 3 mowers were made at least as early as 1949 as we had one purchased with a new WD in May of that year. Was thinking I've seen them mounted on styled WC's also with hand lift. Also, if anyone is interested I believe I have a complete sickle mower windrow attachment in a shed at the farm I would sell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 3:29pm
Yes they were made in '49.......this one has the straight lift lever which indicates it was built in October '51 or later.
  Again,....Mounting brackets for the #3 were made for the B, C, CA, WC and WD tractors.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 6:31am
During WW11 alfalfa seed was in big demand (at least in the Midwest).  One good crop would nearly pay for that ground.  Traveling on top of the mowed seed crop was a no-no; so all alfalfa seed crops were wind rowed as the alfalfa was cut.  Rotating pickups were added to Gleaner combine (the most popular combine in our area) platforms for harvesting the dried mature seed (a couple days later). Herb(GA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 7:03am
Thanks for the great info guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2018 at 8:49am
As I recall we always had a field of red clover in the 1950's and the sickle bar windrower was used when mowing it the second or third time for the year. It was baled for hay the previous times. We had a self propelled Massey Harris Clipper combine with a pickup attachment and after the crop dried in the windrow it was harvested for seed. This was in the fall of the year prior to the first frost.
