Wd45 radiator
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 radiator
    Posted: 01 Dec 2018 at 11:24am
I have a WD45 that has hole in the original radiator. Has anyone bought one off ebay?https://www.ebay.com/itm/Radiator-Allis-Chalmers-WF-WC-WD-WD45-70228587/233023738899?epid=15011440565&hash=item36414c1413:g:8moAAOSwsupb~gMD. I use it a lot for making hay. Please share experiences .thanks Dan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 12:03pm
Gone one through Rick Corder on here.  Fit right in, the only problem I had was the overflow tube.  It wasn't exactly where is should have been.  Otherwise I was REAL happy!!  It was cheaper than on ePay....
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 12:11pm
I've boughten a handful of new after market ones. Most from steiner tractor parts. They have been good. Just ordered another one Thursday.
Carl.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 4:18pm
Rebuild it then you would know what you have. It may be a coin toss on buying new quality wise.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 5:59pm
i have a good used, 100$
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 9:07pm
I'd rather have it recored but that's not as easy as it used to be.The good shops are disappearing.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 9:28am
If you never want to touch it again, get it recored.  I would never buy anything like that off e-bay.  Lot of people think it will fit until you try to put it on.  Questionable quality too.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 9:33am
Recommend OK Tractor, they have good products and service.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 8:00pm
There's a new aftermarket radiator that has a cast iron lower elbow I believe is better quality than they used to be, I know DJS sells them maybe others.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2018 at 10:16pm
Meyers Radiator Shop in Raymond, IL. is good.  Check out Amazon before you buy.  Search "Allis Chalmers".  Saw radiators on there a couple days ago.
WenigBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WenigBill Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 2:09pm
I purchased a new radiator for my wd45 but the threads do not work for the temp sensor. Wondering if any of you have had the same issue?
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 2:37pm
Are the threads boogered up or are you saying they are completely different? Might need a tap to chase the threads and clean them up?
1968 one-seventy
1956 F40 Ferguson
smokechaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokechaser Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 5:14pm
Know this is an old thread, but I too am in need of a '45 radiator.  Any further recommendations? TIA
A-C HD5G, HD3, I600, WD-45; IH 424, B414, B250, Cub; Oliver OC6; Clark R60; Bungartz T5; Ferguson TO-20; MH 44
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 6:49pm
I was quoted 500 dollars to have a WD radiator recore recently.  The shop owner suggested buying a new one for about 200 dollars.
Edited by 1951WDNWWI - 22 Oct 2019 at 6:53pm
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 6:58pm
A few years back before I used Syracuse Radiator locally, in Frankfort, NY, I bought one off eBay and it has been great.
But for a LOT less money, LOCALLY, I'm going to get the old one repaired as a spare. I don't know what shipping both ways would run you, but here's a thread I started about the shop... https://www.allischalmers.com/forum/radiator-shop-plug_topic162783.html?
Might be worth looking into, I have no idea. Good luck!
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 9:38pm
Well , I had to repair a leaker on dad's original 49 WD. Radiator shopquoted $500 for recore and  $187 for  new  import. Warned tanks might not be useable as looked like soldered cracks at stiffener ribs. Turns out tanks were just too iffy to use. Put the cheapy in and so far so good. Just a scoop tractor that doesn't see many hours but gets used a lot. That was only a couple months ago so time will tell. Fit okay.
Tibett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tibett Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 5:23pm
Watch threads for temp guage . Purchased new radiator for wd-45 and threads for temp guage won't work.   Had to put a brass plug in to use until can figure out how to make guage fit. Did purchase new guage same thing
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 7:32pm
I dropped the $500 clams for a radiator that looks like an original (cast bottom spout and everything). So far, no regrets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 11:20pm
Two years later it's still doing fine.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 1:42pm
I purchased two repop Radiators. Both seem to be fine after 4 years on the one, and 6 years on the other.  Looks like Steve M. is doin' okay to so far on his Rad also. I dunno', its a toss up. Whatever floats yer' boat. A couple of the long time Radiator shops round here are now gone. Sometimes you don't have a choice depending on where you live.....
Steve@B&B
