5020 Fluids
Rich. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich. Quote  Post ReplyReply Direct Link To This Post Topic: 5020 Fluids
    Posted: 01 Dec 2018 at 1:27am
Hello,
I bought an 1983 AC 5020, a few months back. This is my first Tractor. It came with an Owner's Manual.
Some of the fluids listed in the Owner's Manuals, I'm not finding locally. I'm looking for alternate fluids. What fluids can I use in place of the below AC fluids?
- Engine Oil: CD(DS series3) Class oil
- Trans/Hydaulic Oil: Allis Chalmers Power Fluid 821
- Anti-Freeze: Permanent Type Antifreeze
- Gearbox: SAE90 gear lube
Thank you,
Rich
1983 AC 5020 Diesel 2wd
john(MI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 1:34pm
I use Rotella engine 15w40 I think is what I use.
I just use whatever Hyd fluid is on sale.  But any should be eual or better thab what you need.
Just regular green antifreeze.  I also include some anti-cavatation fluid.  Not sure where it's available, my friend gave me a bottle of it.  I normally drain the coolant, and then add the amount of fluid needed for the capacity and then add the 50/50 mix of antifreeze and water.
80/90 weight gear lube.
In addition there is a lube requirement for the injector pump.  I don't remember what oil I used, but I was surprised when I found out about it.  It should address it in the manual.
Very nice tractor by the way.  Sure wish mine was like that.
Edited by john(MI) - 01 Dec 2018 at 1:48pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 2:02pm
For the injector pump the book says add engine oil, so I guess it's any old oil.  There is a drain plug, a full plug and a filler cap on top, labelled "OIL".  It takes 3 oz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rich. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2018 at 3:51am
Nice...I can probably get these at the local Tractor Supply.
I was lucky to find this with only 428 on the hour meter gauge.
Thank you. I appreciate all the information, Sir!
Rich
