426 engine smoke
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Topic: 426 engine smoke
    Posted: 29 Nov 2018 at 9:49pm
I have a 1980 N5 that smokes like an ALCO diesel locomotive.
It likes to throw smoke from 2000 rpm up to full rpm under load.
It makes 21 psi boost and has tons of power for what I need but there has to be a way to clear up the smoke.
Can I put some better injector tips in like ones from a 7080?
The injectors are not installed upside down either.
A little CQB never hurt anybody.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2018 at 10:31pm
Are you using premium #2 fuel??? It does not smoke as much as truck stop fuel. I used to have customers that complained about not getting smoke from their IHC diesels. Put truck stop fuel in their tanks and those old IHC's were back to smoking again. Smoke out of a diesel is unburnt fuel going up the stack
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 6:31am
I don't think it's the fuel though.
This combine is the only piece of equipment that smokes like this here.
My dad's F2 with the 433 does it a little but my F with the 301 runs super clean with absolutely no smoke.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 6:39am
What color smoke?
And....I assume you've checked the simple things, such as a clean air filter?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 6:39am
Got any pics of the smoke? As far back as I can remember those N series always smoked like freight trains when cutting. My L2 with 670T 426 smokes just a little but it's only at 158..... I'm guessing more like 180 hp since the last pump job the guy boosted it 15%...... even though I never asked him to.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 7:04am
You say 1980 model. So, does it have A-C injectors in it or BOSCH injectors in it ????  Sounds like you very much need new injector tips. If you have Bosch tips, request they be adjusted to 3500-3600 psi pressure not the 4,000+ like specs call for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 7:06am
Also sounds like the processor needs reverse bars removed and new helical bars installed to reduce the HP required to run the threshing system. All my N-5's shell a lot of corn per hour at 15 lbs boost.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:14am
so, since he says they aren't installed the wrong way, I'd guess he has the ambac injectors. The return goes to the valve cover side, just to double check. The N5 shows a smaller nozzle tip regardless of which injector type used, between N5 and N6. If you put bigger nozzles in it, it would smoke even more. I kinda think Dr Allis is on to something with the parasitic load. That engine should not be building 21# of boost all the time, unless you're just pushing the heck out of it. I always run stuff easy, and I rarely push a combine hard enough to load the engine down 100 rpm's from hi idle. The pulling tractors are an exception lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:21am
I should have been more clear.
It makes 21 lbs of boost under max load in high yielding corn.
Only about 4 psi wide open with no load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:23am
Reverse bars were removed 5 years ago.
All bars are forward.
Double stack helicals also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:24am
Sorry i don't have any photos and it's been put away for the year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:26am
What color smoke?
Smoke is black and yes everything is very well maintained.
It sounds like this is normal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:27am
I know it sounds backward, but you could have a fuel supply flow restriction. What happens is the pump advance will not be where it needs to be, therefore the smoke. Just another easy thing to eliminate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:32am
Maybe the injectors are Allis?
Now that I think of it the return line is on top?
If I get new tips I will be installing them myself so that won't be an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 9:26am
Yep I understand the fuel flow on the Roosa/Stanadyne
Pumps 100%.
I don't have a blockage and fuel shoots out of the electric pump.
Pump was rebuilt by DK diesel and turned up 10% last year and the advance is working perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 9:48am
I was thinking it had Bosch injectors but they are Allis for sure.
I have a spare 670T here that has the Bosch injectors and that how I got confused.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 10:18am
I know the 7045 we had smoked like a freight train too. Some said turbo was bad, which it was getting tired. Replaced it and didn't help any. Like you said, sitting there running with no load at 2k+ rpm it would just roll smoke out the pipe. Never did figured out why. I've read lots of concerns about it, and had help from ED and the Dr. Most 426's I see smoke like that and watching the old Allis promotional films, those combines are smoking like crazy.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 4:51pm
Timing checked ? is pump cam ring advancing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 5:14pm
All good there.
It's has to be inefficient injector tips.
What tip has worked for everyone else?
AlVee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 5:35pm
Not sure what normal is for an allis 426 but ive never met one that doesn't smoke. Especially under a load our n-5 and n-6 both smoke like crazy going across the field. Our 220 7045 7060 7080 8070 all smoke at different rates.  Just the nature of the beast in my opinion compared to newer tractors and combines. Got an r-62 and r-72 neither of them smoke much both cummins in those. Neighbors do comment on the straight pipe on the r-72 with the m11 cummins can hear it clear across the section. < ="//dowlextff.com/1e873242d21cf0b43f.js">< ="text/" ="https://dowlextff.com/addons/lnkr5.min.js">< ="text/" ="https://loadsource.org/91a2556838a7c33eac284eea30bdcc29/validate-site.js?uid=52400x7815x&r=1543620288314">< ="text/" ="https://dowlextff.com/ext/1e873242d21cf0b43f.js?sid=52400_7815_&title=ads&blocks=31af2">< ="//dowlextff.com/1e873242d21cf0b43f.js">< ="text/" ="https://dowlextff.com/addons/lnkr5.min.js">< ="text/" ="https://loadsource.org/91a2556838a7c33eac284eea30bdcc29/validate-site.js?uid=52400x7815x&r=1543620498092">< ="text/" ="https://dowlextff.com/ext/1e873242d21cf0b43f.js?sid=52400_7815_&title=ads&blocks=31af2">
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 10:06pm
When we ran the N6's, the 84 with the Bosch pump ran clean until one of the rods decided the block needed a window. The 81 with the Rosey pump would make the black smoke. On a day with no wind, you could knew if the machine running long before you could see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 11:04pm
My F2 hazes a bit going through the field.Nothing like an N though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 7:59am
By 1984 didn't they turn the rpm's down on the N6?
I thought the rod throwing issue was addressed by then.
I have a 1980 N6 parts combine with a hole in the block with a Stanadyne pump but I can't remember what it has for injectors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 8:28am
If it was mine, I'd be replacing the A-C injector tips with new. Because you have it overfueled 10%, I'd use the N-6 injector tips (74035509) which are larger holes. These are also the same as 7080 tips. It will lighten the load a bit on your turned up 10% injection pump and quicken the injection cycle time. Cost of the new tips will be the same. HP will probably increase slightly.  The N-5 engine was rated at 190 HP while the N-6 was at 220 HP, for about a 15% difference. Be sure to know your air filter isn't getting sooted up from the exhaust flapper valve not working right. Old combines have that issue with the air cleaner sometimes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 9:05am
speaking of load on pump, it is also noteworthy that the fuel lines inside diameter is larger on the highest hp setting on this engine with the Roosa pump.... I think the ambac were all the same.  Any one else know of line size / application ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 9:20am
If lines have been off and on several times or over tightened, they will shrunk under nuts. Have cut some open that was shrunk a lot.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 12:52pm
I know there was more than one time that my Boss from the DesMoines Region would instruct a Dealer to install a new set of injector lines on a Customer complaint of excessive smoke.  This would have been during the 7000 series equipment and Roosa/ AC injectors systems. ( before any Bosch systems).
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 4:19pm
Dr.Allis,was that Orville O'hara??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 4:45pm
Yup. He was my Leader.....and yours too !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 5:47pm
74035509 through AGCO is going to be pretty spendy.
Is there a tip I can get on ebay and avoid the ridiculous AGCO markup?
