18 X 38 Rims
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Topic: 18 X 38 Rims
    Posted: 18 Nov 2018 at 7:49pm
Had a little wobble on the 7045 today. When I stopped to see if I had a low tire, this is what I saw. Anyone have a good rim used or new. Send me pics, price and location if you have 1 or 2 for sale.
Edited by DaveCinIN - 18 Nov 2018 at 7:50pm
AC 7045
AC 190XT with Gleaner L engine
Hesston, New Holland and New Idea hay equipment
OK, so what's the speed of dark?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 8:05pm
Yes but not close to you. Double bevel rims are very common and used by many brands.
Local salvage yard or new is your best option.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 8:06pm
Man, that is a crappy day!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2018 at 11:53pm
Calcium Cloride is the next best thing to sliced bread, isn’t it? One thing that is absolute when you have it in your tires, it’snot IF you rims will rust out, but WHEN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2018 at 5:59am
Man, that's a BIG bummer....better get 2 rims as I fear the right will follow the left....
Friend has a Belarus, that had loaded fronts. One went..he buys one rim.....2 years later, the other one blew out. Cost him 3 down days and a 14 hr 'roadtrip' for another rim...
Do you really,really NEED them to be 'loaded' ?
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2018 at 6:36pm
Thanks for the pic!
Never seen that before!
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2018 at 8:14pm
I'm not up on rim sizes off hand but I have a set of power adjust rims that have 18-38 tires on them that I took off my 210 a long time ago,i can send you pictures by cell phone if you want.I'm located in Bedford,in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2018 at 8:32pm
Paul, it's not bad if it stays in the tubes. These tires were just put on. Tire dealer should have looked at the rims.
Edited by DaveCinIN - 19 Nov 2018 at 8:33pm
AC 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2018 at 8:34pm
I have a pair of rims coming From Anderson Tractor, Bluffton, Ohio.
Edited by DaveCinIN - 25 Nov 2018 at 6:27pm
AC 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 6:30pm
Got the rims in 2 days and they are lightly used. One looks practically new. The other I will clean up a little and paint it. The 7045 is back on all 4.
Edited by DaveCinIN - 25 Nov 2018 at 6:31pm
AC 7045
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 9:03pm
I've got an N ford here with the same problem, guy gave it to me to haul off. His dad bought it new, he could not remember ever having fluid in the tires. He came out the other morning and found it like that, said he was tired of spending money on it trying to keep it running.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 9:23pm
The rusty rim is a problem but Radial tires put more pressure on the rims also. Ive known of a few radials with no fluid split a rim.
