11x7 Drill on a WD45
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: 11x7 Drill on a WD45
    Posted: 05 Nov 2018 at 8:41pm
I mounted my drill on the 45 today and it seems way to close for comfort on the rear tires.. .were these designed just for the WDs w smaller tires? I see some literature says CA and WD mounted drills....
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 9:16pm
mine mounts close also on the 45' with 13.6 tires. it's the one with the gear for the chain bolts to the tractor wheel center. thank it needs to be close. ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 5:47am
I have 14.9s is that my problem maybe?...and they are newer tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 6:35pm
maybe; do you have the gear on the rim that drives the drill with chain?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2018 at 8:33pm
Dawn treader yes but havent hooked it up yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 7:50pm
If it ain't rubbing,go with it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2018 at 12:10am
like steve said;; if it's not rubbing or hitting any thing i would hook it up an use it.
This page was generated in 0.219 seconds.
