190XT pusher bolts
Bob (mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (mo) Quote  Post ReplyReply Direct Link To This Post Topic: 190XT pusher bolts
    Posted: 27 Oct 2018 at 1:02pm
I need to remove the rear wheels on my 190XT to replace the axel seals. The wheels have been moved in the last couple of years so i thought maybe it would come apart fairly easy but no chance. I tried the trick of sliding a chunk of steele between the wedge and wheel useing grade 8 bolts to push and managed to push slugs into all 3 wheel threads. luckily I was able to get everything removed without any thread damage. Does anyone know where to get a set of pusher bolts other than agco's @ $80 a piece? Has anyone ever had a set made at a machine shop I am wondering if they would be as strong as the originals and what the cost would be.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2018 at 8:11am
Here is a picture with a tape next to them. Could be duplicated with a hardened gr8 5/8 bolt, a threading kit, and a lathe or grinder and time.
https://www.allischalmers.com/forum/just-got-a-190xt-and-have-a-few-questions_topic123812.html
Edited by Hurst - 28 Oct 2018 at 8:12am
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (mo) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 5:03pm
update:Had no luck locating any push bolts so before i made the drive to the machine shop with the specs.I came up with some 1/4" hard steele pieces placed them between the wedge and the wheel and cranked away with grade 8 bolts and much to my surprise wheel center slid right off. I had already picked up the oil seals at my local Agco dealer part #70246564 @ $42.07 each which after close inspection they are made by National part #416292 available from Rock auto for $13 each or the local parts store for $22 each. lesson learned. Anyway one side done now on to the other side.
This page was generated in 1.184 seconds.
