WD45D water pump |
OrangeFever
Joined: 25 Apr 2010 Location: Eastern Iowa Points: 122 |
Topic: WD45D water pumpPosted: 17 Oct 2018 at 5:41pm |
Bought an aftermarket water pump for our wd45 diesel and there is no dowl pin on it. Im going to drill a hole for one and install a pin. Has anyone else came across this issue?
Matt (Jordan,MN)
Joined: 12 Sep 2009 Location: Jordan, MN Points: 3814 |
Posted: 17 Oct 2018 at 9:21pm |
What dowl pin? The only pin there is in the gasket and that goes in the small hole in the head.
Owner of Matt Scott LLC
Specializing in NOS and used Allis Chalmers tractor & implement parts & liturature and Magneto Repair http://www.mattscottllc.com/ |
OrangeFever
Posted: 18 Oct 2018 at 5:56am |
Thats what im talking about Matt. There is no pin thru the back plate to keep the pump passages in alignment to the head.
Matt (Jordan,MN)
Posted: 18 Oct 2018 at 10:34am |
The little pin that's in the gasket keeps the gasket lined up with the head. The water pump is kept in alignment with a short peice of flat steel that bolts to the back of the water pump and to the front of the block.
OrangeFever
Posted: 18 Oct 2018 at 4:39pm |
Thanks for your help. I found the bracket!
