Block heater questions
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Topic: Block heater questions
    Posted: 15 Oct 2018 at 8:52pm
So I ordered a couple of the kat 30208 block heaters.   I needed one for a 185 we are working on.   I also thought I'd get one for my 190xt. I never looked at the block but my block is not machined for the flange of the block heater.   No big deal I'll put it on my 180. So I'm wondering if anybody knows if any other style of frost plug heater will work in a 190xt. Also wondering if there is an aftermarket source for the block heater on an f2? Friend of mine who bought our old f2 is looking to replace it. Seems like I looked into getting one from agco once but it was pretty spendy. They look the same as the 30208 heater other than they have a tube coming out that is routed you the rear of the engine and is hooked to a hose.
Thanks
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 12:50am
KATS 30208 heater, 2 bolt mount fits 180-185-200 should fit 190's unless frostplugs different.
On AC200 tractor block heater goes in plug at right rear of block, 190xt's should be same. On 180 & 185 heater goes in Rt center plug shares bolt hole with primer pump mount, cleanout threads with tap in unused hole before trying to install bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 1:04am
Forgot to add this; on the center hole there is a shoulder in block that keeps plug from going in to far. "Do Not try to drive it into block for removal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 9:53am
My 190xt does not have the bolt holes or flat surface for the 30208 type heater, that's why I'm looking for a different style of heater that will fit into the frost plug hole in the rear.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2018 at 10:43am
Our XT has a couple of flat spots,but no tapped bolt holes ??
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 11:21am
Here is a long post I submitted related to installing a block heater that I did last year in my 190xt.  My 190xt is around 1968 and did not have the easy flange plate.  I knocked the frost plug out above the starter and installed it.  I ended up using the ZeroStart model with success.  My install still hasn't leaked after almost 1 year and I love plugging it in for about an hour or two and fires right up.  Good luck and hope you learn from my mistakes and issues.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 8:19pm
I recently installed a Kat's P/N 11618, 600 watt, 35mm frost plug heater on my 1968 190XT.  I made the butterfly wings as narrow as possible, lubed the o-ring, inserted the element at about one o'clock and torqued the machine screw to 15-19 inch pounds. It was a nice snug fit w/o any modifications. I didn't like the five foot cord that came with it, so I bought a Kat's P/N 28201 one foot cord. Be sure to use some very fine sand cloth to clean up the hole where the o-ring seals. Around here, Auto Zone has it listed for $25 on line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 8:44pm
Ok, thanks guys.   This is the kind of heater I'm looking for.   I will have to order one when I get a chance.   Busy combining now.
