My 1949 WD ( Originally my Grandfather's )
Hockeyman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Topic: My 1949 WD ( Originally my Grandfather's )
    Posted: 10 Oct 2018 at 3:42pm
Here's a picture of my WD. Was originally my grandfather's, was sitting in the garage unused and forgotten about for 25 or so years. The engine was dry seized, block froze and cracked behind the carb... I repaired the crack with JB weld after drilling it out and grinding the block flush. Also fixed the radiator with JB weld on a seam or two.
Tried soaking cylinders with ATF, acetone, coke, etc trying to free them up... But I had to force two pistons with a block of wood and a hammer... Rings were rusted to pistons. Heat, soaked, heat, eventually the rings broke off in pieces. Pistons were then cleaned up and I installed new old stock rings found online. Plastigauged the connecting rod bearings and all were well within spec. Installed oil pan gasket after watching Don's video a few times. Had trouble getting the push rod cover gasket I cut to seal the first time... But the second cut gasket worked better and doesn't leak.
Added water in to the rad... Thermostat housing was leaking. Broke two of the bolts on the housing. Drilled out and re-tapped the holes. Installed new gasket and lots of RTV to seal it up.
I rewired the tractor front to back, installed new wires, plugs, points, and 6v battery.
Fired up nicely, and is purring like a kitten!
Here's the cultivator I drove 26 miles round trip to pickup from my aunt's yard this past weekend. Just need to fix the leaking plug on the hydraulic pump now.
Cernunnos View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Cernunnos Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 4:56pm
That is a neat cultivator set up.  Have not seen one exactly like that before.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 5:10pm
I have several of those type tool bars..
hillmonkey View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 5:48pm
Nice tractor,glad you saved it.Wondering how the cylinders looked and did you hone them?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 6:43pm
Hockeyman,
Great job bringing this family tractor back to life! You have put a lot of work into it already. Whats your plan for it?
JimWenigOH View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 7:11pm
Nice save on both pieces. I bet it was pretty exciting to hear the tractor run again. Thanks for sharing some photos of your heirloom with us. ClapThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 7:20pm
Cylinders were actually in good condition... The rings seized in the pistons so the cylinder walls were virtually rust free. I did use a ridge reamer and hone on each of the cylinders to ensure the new rings had the best surface to mate with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 7:32pm
Hockeyman,
The long term plan is a full restoration but at the moment I really wanted to get it to run.
Short term plan is to bring the remainder of my grandfather's implements home, AC tow type two bottom plow with an interesting hitch (looks like a pintel type), potato digger, and potato planter (future lawn ornament).
Once I have them all in working condition the plan is to use them around my acreage... I have a garden in which the plow, cultivator, and potato digger will come in handy. I also plan on establishing a spruce tree line around the perimeter of my property. My daughter and I started a bunch of seeds when we first moved in almost 5 years ago so they are finally big enough to be moved to their permanent homes around the yard.
My grandfather also had an AC B which was sold to a family friend 30 years ago which I'm also hoping to get back into the family. Just waiting for him to want to sell it...
HudCo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 7:39pm
graet to see it going no matter what you have to do to it will be .      " the most tractor, and hardest working,  that you can buy for the money"  thats what my grandpa always told me about his wd's wd45's and d17 's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 8:43pm
Sounds like a good plan. Similar to what I did with our family tractors. Got them running and moving to see what needed fixed next. Will be watching your progress. (no pressure here:))
Dan Hauter View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 8:53pm
Congratulations on your hard work and persistence!  It's great that you've brought this family tractor back to running condition.  Best wishes on completing your project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 9:54pm
I must say it did feel amazing to hear it fire up again... Lots of great memories sitting on that toolbox as a kid with my grandfather. Now I can share it with my kids... When my wife isn't watching us drive around
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 10:01pm
It's a neat setup for our heavy clay soil... I need to replace the rotted board that supports the rear tines. There's always something that needs a little tlc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 10:12pm
I won't be doing much now till spring comes around... Have to winch or pull the other implements out and onto a trailer once I clear more brush at my aunt's for access. Was a nice drive there and back on the WD for the cultivator but the weather here is getting cold. I had the shutters mostly closed and I could barely get the engine up to operating temperature.
Just need to give the WD a good hot water wash and then winterize it.
Bill Long View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 3:47pm
Hockeyman,  You have brought back to life and will continue to restore a most valuable tractor - Your Grandfather's.  What a wonderful chore.  I can just imagine all the memories this brings back.
Every time this comes up I always talk about - i know this is boring - finding the first "flat top" WC my father sold.  I saw it once and it got away.  Have been kicking myself ever since.
Congratulations!
Let us know how it goes - really does not look bad now.  Send us pictures.
Good Luck!
Bill Long
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 10:29pm
Welcome to the forum also. Great save. Lots of people take great pride in haveing family history
HD6GTOM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2018 at 10:40pm
I've had a couple of those field cultivators, but never seen 1 with a hitch like that. Congrats on the tractor.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 11:15am
I have a cultivator like that, do you have the yoke that bolts near the belt pulley under the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 5:49pm
Memories are a wonderful thing and you've done even better, you've go the tractor!!
CONGRATS!!!  Glad it didn't take much to get it going.
WELCOME and good luck with it!!  Grampa must be smiling down on you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 11:25pm
Congratulations!
Good Luck!
Bill Long
Thanks for the kind words... Memories that we never want to forget we share with others. That way when Alzheimer's kicks in, people who we shared those memories with will remind us
The tractor needs a good hot water wash... Covered in oil and dirt from many acres farmed and the rare washing.
I will take more pictures once its washed and winterized.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 11:33pm
I do not have a belt pulley on this tractor. The support that is affixed to the tractor frame does connect to the toolbar / cultivator frame as does the other connection to the front of the drawbar with pins. I can take a better picture once its washed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hockeyman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2018 at 11:42pm
I'm also glad it wasn't much to get going... Found lots of good deals on parts online, mostly new old stock items or last of old inventory. Eventually I'll have to put new sleeves and pistons in as the ring gap was near the maximum tolerance. But for the occasional use I'm confident it will be fine for years to come before I do a full go over of the engine, paint, and re-decal.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 7:03am
Great that you have your grandfather's tractor and are caring for it.  Interesting cultivator.
On the tractor at the front of the battery there is a "bail" looking bracket that goes under the tractor frame, what is that for?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 8:43am
To me it looks like the hookup point for the front bracket on the cultivator pictured.
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 9:54am
Nice job getting it going. I have read so many “In search of family tractor “ stories.
Keep up the good work.
WD/WD45 are my favorite model.
Thanks for sharing.
Ray W.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 10:08am
Don't need a photo for me, I have one and was just wondering if you had that piece for yours, looks good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2018 at 10:10am
Just went back and looked at the picture, that yoke is on the tractor as pictured, should have looked closer first.
