AC D17 LPG Help
VooDooChikin04 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VooDooChikin04 Quote  Post ReplyReply Direct Link To This Post Topic: AC D17 LPG Help
    Posted: 08 Oct 2018 at 2:13pm
By any chance does anyone know where the fuel cutoff would be for the LPG D17? I have a copper line going from the LPG tank directly into the ensign regulator/converter.  Here is a picture of the unit.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 8:36pm
The fuel shut off is the valve on the tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 8:45pm
There is a valve inside the regulator that shuts fuel from regulator to engine.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote VooDooChikin04 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 9:01pm
Haha. Yes I know where the tank valve is. I meant the fuel shutoff valve that only opens when the engine is cranking via vacuum. Sorry I should have been more specific.
So it's inside that dang regulator eh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 9:02am
If something is wrong in the converter/regulator parts for the ensign are made of unobtainium..unless you can find a LP dealer that might have some old stock laying around
Post Options Post Options   Thanks (0) Thanks(0)   Quote VooDooChikin04 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 8:35pm
So I've heard.  According to the service manuals diagram of the ensign converter it seems pretty basic.  Luckily I have the capability to make parts and or have parts made that I need SO im hoping I can accomplish that.  After reading the service manual I believe that the low pressure valve is leaking due to debris since the previous owner did a filter delete... SMH....
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 2:17am
Do yourself a favor and change it over to an Impco regulator and carburetor. I have a couple tractors both the original Ensign and Impco and the Impco are easier starting and run better.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 6:23am
If you need any parts or advice call Dave or Phil at Carb and Turbo at 952-445-3910. They are in the Twin Cities and are very helpfull. They are the official tech reps for Impco and are great guys.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 10:35pm
Everharts in Oklahoma is an Ensign parts dealer
Can't fix stupid
