Pin hitch 2 bottom plow
Pete32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Topic: Pin hitch 2 bottom plow
    Posted: 01 Oct 2018 at 2:32pm
Does anybody have any pictures of how a 2 bottom pin hitch plow hooks up to the drawbar? Also, where can I get the pin for the plow, or is there something I can use in place of the pin?
I bought a two bottom plow that was converted to a snap coupler plow but I’d like to go back to the pin and drawbar set up.   The homemade snap coupler is bolted in place where the pin would go. It looks a little sketchy. Thanks
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 2:46pm
A pin hitch plow doesn't hook to the drawbar....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 3:01pm
Sorry, I may be calling it by the wrong name. Here is a picture of the same plow, but mine has a homemade snap coupler where the pin is on this plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 3:10pm
The plow in the picture actually straddles the drawbar, so yes, the drawbar in this case does get used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 3:23pm
Yes: to hitch a WD pick-up plow to a WD, first you adjust the drawbar to its shortest length. Then back into the plow and drop a pin, any pin, into the plow. Then remove the pins that set the height of the drawbar bail. The bail is left in place and allowed to float. Then attach the two coupler to the lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete32 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 3:25pm
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 4:00pm
There is one more thing. An old WD that never had snap-coupler, the drawbar bail will not fall off of the tractor when you remove the two height position pins. The bail cannot fall off of the tractor and will free swing. If it has been converted over to snap-coupler, the bail has been modified to slots on the ends, so the bail will fall off the tractor when the height pins are pulled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:26pm
Guess I stand corrected. Must have had something else on my mind, perhaps the CA plow. Anyone have a photo of this plow hooked up?
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:42pm
Don't forget you "might" have to pull the pto shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 10:36pm
You better pull the pto shaft or you will hurt things at full lift. Dad had piece #9 wire welded to pull pin that reached the right length and L hooked on end.He would set it upside down in slot on step plate for pto shield and it reached down and held drawbar correct height to back into plow tunge.
