7020 head gasket |
Post Reply ![]() |
7060 ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Sep 2018 at 9:28pm |
I have 500 hours on a overhaul on my 7020 and it’s seeping a little engine oil out the left around the head gasket. I didn’t retorque like I should have, but is it too late? Just lack of bolts on the outside edge of the pushrods?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21834 |
The result will be 50%/50%. It will either work or it won't. Loosen each bolt maybe 1/4 turn first and then torque back up to 165 ft lbs.
Big Orange ![]() Silver Level ![]() Joined: 11 Sep 2009 Points: 315 |
Remove each head bolt one at a time, coat each bolt thread & top under the head with neverseeze, retorque bolts, check the torgue wrench for accuracy. GOOD LUCK
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3530 |
How'd it turn out? Did you re-torque or remove/never-seeze each bolt?
8070220 ![]() Bronze Level ![]() Joined: 17 Jul 2018 Location: Red bud il Points: 77 |
U always get them up to time and retorque them .we torque all our to 175 .u shour it head gasket and not the turbo sucking oil and come out intake .
I just pulled it in the shop to do it. Resealing the steering cylinder and going to probably back them out a little and retorque the head. It is seeping right along the intake manifold, but I did put a new turbo on with the overhaul. The valve cover gasket is dry too. I’ve never had one leak before, but I did use a reliance gasket and I’m wondering if I should have used a agco even though agco doesn’t make it I’m sure. Does anyone use aluminum paint anymore?
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
I would pull intake manifold to make sure there is no oil in manifold. MACK
Post Reply ![]() |
