RE: Weights |
Kurzy
Joined: 02 Nov 2009 Location: WSS, Montana Points: 808 |
Topic: RE: WeightsPosted: 24 Sep 2018 at 8:28am |
Howdy, What is the weight of the starter weight on a one seventy? Thanks Kurzy
DrAllis
Posted: 24 Sep 2018 at 8:51am |
I always thought a 180-190 starter weight was 250 lbs. The 170 is a bit narrower at the side frames, so I assume it is a different part ?? Been too long ago to remember for sure.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10880 |
Posted: 24 Sep 2018 at 9:00am |
I was thinking 275 pounds IIRR. They are all one person wants to handle. HTH Tracy
Kurzy
Posted: 24 Sep 2018 at 1:37pm |
Howdy Tracy, All one man wants to handle!!! 275 lbs. I weigh half that! Thanks Much
DrAllis
Posted: 29 Sep 2018 at 6:36pm |
Finally remembered to look this up in my old collection of advertising literature. The big starter weight was called 280 lbs and the smaller add-ons were 75 lbs each. The 170 starter weight must be the same as a 180-190 because they weigh 280 lbs also.
Kurzy
Posted: 29 Sep 2018 at 7:06pm |
Howdy DrAllis, Wow ! Thats no one man job. Looked at a one seventy with starter weight and did not look 280 pounds. But I got all weights coming will find out! Thanks Kurzy
Unit3
Posted: 30 Sep 2018 at 7:26am |
I am sure it would NOT work but if you used 2-2"x6". Run them from the tailgate of your GMC to the front axle of the tractor. Could you slide the weight over and be the right height to mount the weight?
Nah, CAT forklift would be my tool of choice.
Kurzy
Posted: 30 Sep 2018 at 8:05am |
Howdy Unit3, Thanks for the idea But paint first! Kurzy
