diesel fuel tanks
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Topic: diesel fuel tanks
    Posted: 18 Sep 2018 at 4:41pm
got a real nasty fuel tank on my d-15 diesel Put vineger in it then flushed it out with hot water still a mess
Any ideas short of removing it and having a radator shop boil it out
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2018 at 6:08pm
had a bad tank on a truck' used some lacquer thinner; broke the crap up an washed it out' old fuel can get like dog poop;
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2018 at 9:29pm
bendix carb.cleaner worked on mine.....
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2018 at 10:25pm
When you get it cleaned up, put a new cap on it.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2018 at 8:45pm
I think the most serious challenge of this question is "Take it off"...
Removing the tank, IMO, is the key to getting the best tank-cleaning possible.
I remove tanks, cover up the holes, put three handfulls of old bolts, nuts, and washers in the tank, then put it in my tumber (stuff styrofoam and cardboard around it tight, and strap it in with rubber hook-straps) and turn the motor on... the hardware drags around the inside and loosens up stuck stuff.  With some thinner petroleum product, it'll break the goo=factor down substantially... after a few iterations, the come out shiny clean.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2018 at 7:50am
E-85 works great as a cleaning solvent to cut the old crap fuel. Seems better then straight methanol, or straight gasoline. Must be the blend, not sure why, but it works great, and is cheap. Just have to be very careful, since it's very flammable, and it stinks bad!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 10:00am
If you don't have a tumbler, you can strap the tank to the back wheel of another tractor and go for a ride. Another alternative would be let it ride around in the back of a pickup.
