how to polarize a three brush generator on C
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: how to polarize a three brush generator on C
    Posted: 10 Sep 2018 at 4:42am
Hi
I would like to polarize the generator on my Allis C. It is a 3 brush genrator 6 volts;
How i can do it?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 7:21am
Momentarily jump across the cutout relay on the generator. All it takes is a quick spark. Use a piece of wire about the same thickness as on the tractor.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 9:27am
Do that polarization before you start the engine the first time after installing the repaired or shop tested generator.
The three brush generator is normally used without a voltage regulator and the function of the third brush is to act as a current limiter so the generator won't be overworked by a low battery. Its up to the operator to back off the generator with the light switch to keep from over charging the battery but also to be sure the battery is full charged.
Gerald J.
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 12:14pm
Is determining if its a 2 brush or 3 brush as simple as opening the band and counting the brushes?
5 Steigers, 7 John Deeres, 8 Internationals, 4 Case tractors and combines and 1 Oliver
........... Oh wait they're all 1/64.......and a real '44 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2018 at 6:26pm
Yes its that easy. But its very likely to be a three brush generator if it has only a cutout and no voltage regulator. The third brush causes a current limiting operation from the magnetic field from the third brush and protects the generator from a battery that would draw more current than the generator is built for. A voltage regulator with three coils inside uses one for cutout, one for voltage regulation, and one for current limiting so the third brush isn't needed but it doesn't hurt much either.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 2:35am
Gerald , does it means , that il i put a three coils voltage regulator, i can remove the third brush?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2018 at 9:49am
Yes the generator will work fine with the third brush and the voltage regulator with current regulator. If the current setting for the current regulator part of the voltage regulator matches the design current rating of the generator, the third brush isn't needed. Getting the voltage regulator with the proper current rating is another variable to be matched along with the wiring of the field that is not so common with the AC generator.
Gerald J.
