D17 with a JD B grain drill; hydraulic question |
Post Reply ![]() |
D17SeriesIV ![]() Silver Level ![]() ![]() Joined: 26 Jan 2015 Location: Hartwell, GA Points: 82 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Sep 2018 at 8:36pm |
Hello all! Got my D17 Series II back up and running. My neighbor gave me an old Deere/Van Brunt B model grain drill that also needs some TLC.
When I got it here and figured out how to hook the hydraulics up to the remote, the cylinder on the drill worked suprisingly well. That was about 18 months ago, so I'm assuming I got lucky last time I hooked it up or something because today it wouldn't hit a lick at a black snake. I have the manual for both the D17 and the drill, but wanted to pick your brains as to what I may be doing wrong, or if there's some tribal knowledge in here on what may be up with that hydraulic cylinder on the drill? Thanks in advance! Glad to have the old girl back up and running, still got a long row to hoe before I'm done though ![]() Edited by D17SeriesIV - 04 Sep 2018 at 9:39pm |
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
What do you mean(won't hit a lick at a black snake) tractor won't start? Cylinder won't work? Or what? MACK
When I hook the drills cylinder to the tractor it won't doesn't work. Wondering if I'm hooking the lines up wrong, or if the cylinder in my drill is malfunctioning.
Is hydraulic full of oil? Is foot clutch out? Do the two hydraulic couplers look the same? Both ball or both points? If points, is one shorter than other? MACK
I got it to work, the lever for the lift arms wasn't locking into the carry position all the way. That little nub that holds it in place is pretty worn. And you were right about the fittings, one is a point. Going to TSC to replace it today.
This morning I'm making some temporary down tubes out of that black water line left over from replacing our foot valve just so I can test it out. Spring for the gear hanger on the right side broke, but an old trampoline spring is holding for now. It's pieced together for sure right now, but it'll make due until I can get the right parts. Thanks Mack! Edited by D17SeriesIV - 06 Sep 2018 at 8:39am |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3062 |
Is the cylinder on the drill an Allis cylinder? A D17II should put out 3000PSI or more and a standard cylinder is only rated at 1500-2500PSI depending on the cylinder.
You could blow the cylinder apart after awhile
Edited by Allis dave - 06 Sep 2018 at 11:13am |
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1030 |
I have seen on this site many times where a D17(and other models) would or could blow a Hyd. cylinder apart if it wasn't one of the old AC cylinders. I have a D17 ser.3 and have used a regular 3x8 cylinder for years and years on disc harrows,haybines,hay tedders and just about anything you can imagine and never ever had a problem. Is this a myth someone started years ago or can it really happen?
The cylinder on the drill is an unknown. It isn't the stock option. The neighbor I got it from is more of an "I'll make it work" type guy. I have a 3 bottom plow he loaned me a few years ago that is 2 different old Oliver plows and one JD plow welded together pretty much.
I did replace the point connector on the drill with a standard today, now the old standard end is leaking. |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3085 |
I've used regular cylinders with AC tractors with no problem,have one on a NH 456 mower I'm using now pulling it with a D15.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12186 |
That being said, the pressure in a cylinder is still only what's required to lift the load, which on most implements is way under max pressure the tractor can deliver. Therefore, a case where you're trying to lift something the cylinder can't and the system develops max pressure is when a cylinder might rupture. There's the very brief spike at the end of stroke also. THAT being said, cylinders are designed and built with a "factor of safety" where burst pressure is higher than rated pressure. So, is it a myth? No. Can it happen? Yes. But as your observations show, it's not common. |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
About the only way to hurt any hydraulic cylinder with a High pressure Allis hydraulic system, is to run it to the end of the stroke and let the pump hammer away at it. That is also kinda hard to do when the Allis had a relief valve that will dump at whatever pressure it is set for.
The isn't a cylinder made that will blow up under it's rated pressure, probably more like 2 to 3 times their rated pressure, or there would be lawsuits going on all over the country. |
Post Reply ![]() |
