D 15 Series 1 Starter |
Post Reply ![]() |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3034 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Sep 2018 at 1:59pm |
Pulled my starter as all it'll do is click . Sure looks worn out. I'm boxing it up and sending it to Steve for a rebuild . Under the starter is a maybe 1" by 6" lever? Anyone know what this is ? One end is attached to the top of the torque tube . Other end has a hole but not attached to anything . THANKS
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22065 |
They all have that. Belt pulley shifter.
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Put belt pulley in gear . Hole in right of dash for rod to come through.
Ok , no wonder it's not hooked up . Don't have a belt pulley . Thanks !!
Also wonder how the starter nose cone gets broken . Mine has been welded . Our diesel D 15 starter has too .
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6496 |
Lots of torque on the starter and over time hard engagements or a bit of binding/misalignment will cause them to crack.
Go Dawgs!
Makes sense . Thanks
Post Reply ![]() |
