My newest acquisition
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: My newest acquisition
    Posted: 01 Sep 2018 at 4:03pm
I recently acquired this steel wheel B. The engine is set, but I have a C that is very rough except for a very good engine that may become a donor, or I may rebuild the original engine. I have both steel wheels with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 4:05pm
Good looking little tractor. All the sheet metal looks straight. Got a lot of potential there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 4:07pm
The grill is has a jam around the crank, but other than that it's pretty good for a 75 year old tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:34pm
Is the starter delete plate still in the hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:50pm
It is, but I will probably put a starter on it. I have a 39 B and I seldom use it because I have to crank it. I probably won't put a generator on it. I will use a 12 volt battery and charge it when it needs it.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 7:55pm
If it interests you, my b is a 39 with no Genny on the engine. Some one had 1 mounted under the seat, V belt runs off the belt pulley. It was professionally done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 8:14pm
Nice find!
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:08pm
great find! the dent by the crank hole doesn't look serious
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:39pm
Those fenders are different. Are they unique to steel wheel tractors? I haven't seen them before.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 9:40pm
Yes.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 10:08pm
Fenders, tall breather. What is the sn?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 10:19pm
Yea... fenders and air inlet stack are nice....... and the rear wheel hubs with 4 notches are also time correct.... Why the one rubber tire ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 5:50am
I think they probably changed it over to rubber tires at one time, but I did get both steel wheels.
According to some of the neighbors at the auction, the owners had bought the tractor new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 6:02am
The serial number is B60171, which makes it a 1943.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 8:34am
Very nice! Congratulations! That is a unique tractor. How many steel wheel versions were made?
This page was generated in 0.131 seconds.
