180 allis chalmers hard starting
chuck linn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck linn Quote  Post ReplyReply Direct Link To This Post Topic: 180 allis chalmers hard starting
    Posted: 01 Sep 2018 at 6:08am
Gas 180 is hard to start on gas one shot either and its gone carb rebuilt but still floods sometimes new float needle and seat new points and condensor new plugs still doesnt seem fire hot enough on start runs well after getting started thanks for any help
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:47am
I don't have the fix as ours has the EXACT symptoms (ours will some times pour gas out of the air hose/carb connection) but NEVER pull the choke,pull throttle back as far as you can and push the start button. It will "hit" and start then start feathering the throttle back and forth until it smooths out and idles normally. We have done this ever since we have owned it. This happens to ours when it sits for more than 4 days without running. Yes, we have done several carb re-builds and major tune-ups to no avail. Once it gets going, it is a strong,smooth runner!! Hopefully someone gives you a "mechanical" fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2018 at 6:56am
I would put a MSD6 ignition on it.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 6:00pm
We purchased a true NOS carb from Roberts  Farm equipment&Tractor parts. Starts like a dream now, should have done it years ago!! It did need to have the floats adjusted though.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2018 at 9:07pm
Bad gas with a lot of moisture in it.  Drain and clean the tank and refill with FRESH gas from the station (not the big barrel by the barn that can collect a lot of moisture).
Have you replaced the distributor cap?  Might have a hairline crack in it somewhere.  How old are the spark plug wires?
Edited by DSeries4 - 17 Oct 2018 at 9:09pm
This page was generated in 0.170 seconds.
