What knob to use on a CA final drive lever?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: What knob to use on a CA final drive lever?
    Posted: 30 Aug 2018 at 5:55pm
Hey guys I've got an early CA and the final drive lever does not take the standard knob called out in the parts book as mine does not have threads.
What have other people used when they ran into the issue?
Edited by nowaktj - 30 Aug 2018 at 5:57pm
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:08pm
It wouldn't take long with the appropriate die to cut threads. Last I looked McMaster-Carr carried threaded knobs. http://www.mcmaster.com
 Or you could start with a universal knob and drill it to fit the shank and then drill and tap a set screw hole in the side of the knob.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2018 at 9:52am
The knob in the pic looks to be just a push on type, sold by vendors on here.  Like this one
http://oktractor.com/zen/index.php?main_page=product_info&products_id=172
I have TWO CA's and this knob is on both of mine.  Neither has threaded handles.  HTHs...
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2018 at 9:57am
Thanks for the info...I did measure it and it comes in at .540 so cutting threads on it would be difficult (1/2-20).
Edited by nowaktj - 03 Sep 2018 at 9:57am
This page was generated in 0.289 seconds.
