CA Rockshaft ?
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA Rockshaft ?
    Posted: 20 Aug 2018 at 9:03pm
Is there a difference between the Snap Couple and pin hitch rockshafts?
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 12:32pm
Yes about 6 "
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 3:22pm
The pin hitch is longer
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 3:47pm
He’s asking about the rockshaft, what the lift cylinders control, not the drawbar on the implements.
Yes: the rockshaft is the same for both the pin hitch and snap coupler tractors is the same. For the snap coupler tractors have the end holes cut off.
Shade Tree View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shade Tree Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 7:20am
...Is there a picture description for changing CA pin hitch to snap coupler...showing all parts needed and change over procedure.
...Also, is there a good topic to show parts and procedure to change to 3 point...after-market or factory.
What is the best after-market 3 point for CA
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 8:45am
My CA has the Snap Coupler. I have a Woods L306 mower on it. I had to take the Snap Coupler bell off because of the belt clearance. I  wanted to put a drawbar on the tractor. I bought a pin hitch drawbar at an auction.  I put it on the other day, my original question was if there was any difference in  the lift arm length.  My rockshaft did not have the end holes on it like the pin hitch rockshaft, but it still let me hook the pin hitch drawbar up.  To change from pin hitch to Snap Coupler requires the lift arm latches, bell, and release lever. The end of the lift arms have to be cut off so the lift arm latches will fit. I have a Cross Mfg. 3 point adapter. It is made for a  Snap Coupler, the same hitch is used for a pin hitch, just has a piece of pipe welded to the Snap Couple eye for the pin to go through. I bought it from Cross Mfg. they are just 20 miles from me. It is well made and easy to hook up and take off. Reasonably priced as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 3:08pm
Yes Rusty it's like I said the pin hitch has longer arms, it wouldn't take a lot to make a adaptor or bolt on extention to make the pin hitch drawbar work.
Edited by tadams(OH) - 22 Aug 2018 at 3:11pm
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 8:03pm
I have the CA Snap Coupler rockshaft that I drilled a second set of holes on each arm to mount the old style couplers to use on my homemade version of a 3 point adapter but I do not have my Anti-sway chains installed in this photo. I can still use the later version of snap couplers on these lift arms.
DeWayne
