Easiest way to replace fan belt 6080? |
Post Reply ![]() |
rudyk ![]() Bronze Level ![]() Joined: 20 Apr 2016 Location: camdenton,mo Points: 151 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Aug 2018 at 7:39am |
Broke the belt on my 6080.
Just seeing if their is a simple way Thanks |
TJ Shaw ![]() Bronze Level ![]() Joined: 09 Jan 2010 Location: Nebraska Points: 20 |
If it has the saddle on the crankshaft, you have to remove the two bolts and spacers on either side of the saddle. It's pretty straightforward after that.
WNYBill ![]() Silver Level ![]() Joined: 04 Jun 2016 Location: WNY Points: 276 |
Unlike the green tractors....... you don't have to remove the radiator!!!
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24715 |
easiest ? pay someone I suppose... all fun aside, be sure to buy TWO belts. Install one,store other in a safe KNOWN place.
I guess you have room to weave belt over fan blade?
PeteMN ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 205 |
Like was said in previous post, if you have the bearing support mechanism on the end of the crank just remove the two top bolts and spacers, thread the belt over the fan blade and under the crank pulley, replace the bolts/spacers, install belt on the alternator, tighten up and good to go. Factory belt was too long for my 6080, so I bought one an inch shorter and was able to get the belt tight enough so it didn't slip on the alternator.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54213 |
Thanks guys
It went on really easy with your help |
soybreedingboy77 ![]() Bronze Level ![]() Joined: 14 Dec 2011 Location: Illinois Points: 185 |
I have a 6080 w/ cab and AC. I have put 4 belts on in 2 years. 2 of the belts did not make it 10 hours before flipping. All AGCO belts.
Any thoughts as to issues to check? Alternator shop said to put a little thicker belt on, thought that the "slipping" over the years may have wore down the V in the pullys. NAPA and AutoZone both have a belt that is next size wider. Will try one of those next time. |
Oreillys had 2 models, one was a heavy duty and that was what I got
Post Reply ![]() |
