190XT Engine in D19
barnabas_12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Engine in D19
    Posted: 15 Aug 2018 at 2:15pm
Can I put a 190XT engine in a D19?    The D19 is stuck and I have an opportunity to buy a good running 190XT engine.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 2:21pm
301 is longer.  have to rework steering and front end.  its not a drop in
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 2:27pm
BTW - my D19 is gas, the 190XT engine is Turbo Diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 4:00pm
There was a recent post on just such a swap only with the 4-cylinder version. Less than 90 days ago. The power steering cylinder is a real issue.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 4:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 5:19pm
Thanks for the replies.   Sounds like I need to wait for another D19 or perhaps 180 gas engine to show up.
Here is the link to the 190XT engine.   I won't be bidding, but someone else here might be interested.   Ending soon now.
https://www.proxibid.com/Heavy-Construction-Equipment/Light-Equipment-Support/Allis-Chalmers-XT190-complete-engine-on-rolling-stand/lotInformation/43517840
chuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 5:57pm
I believe a 180 gas would be about as much work as a 301, depending where your at there's a fair amount of combines with engine's that will fit in there.
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 5:57pm
$350 is high bid, ending in 10 minutes?  Man, If I had the room, that would be mine.  WOW, if halfway close to there and room in the corner of a garage... I say jump, that's a steal!
Man..... I can't do it... can't do it........  IF I had not just dumped alot of coin on something else this morn..... seriously.... something's gotta be wrong... I would love to know what they used this set up for??
Edited by NDBirdman - 15 Aug 2018 at 6:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:00pm
I'm close, but if it doesn't fit … I thought about getting and swapping someone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:04pm
Seriously.... I spent a lot more than this on rebuilding a 226 head...... wow...
Even with a 19% premium.... wow
OK... as I suspected, last few seconds it shot up but still, it went for $750, I think it went way too cheap.
Edited by NDBirdman - 15 Aug 2018 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:08pm
Sold for $750 - Stand was pretty neat too.   Probably not many hours.   Hopefully a deal will come by on something that will fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:29pm
Isnt that 19 % premium a dam joke ! Its all so easy ,, just punching keys on a keyboard !
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:37pm
Barnabas, 180 engine won't work any better than a 190XT engine... same dimensions...  But it is possible to be done.+
D19 with 190 engine...
 anything is possible, this engine has the Simms pump... sure would have been a honey I think if it was running.
Looks like this 19 had some real heavy inside weights in the rear wheels...
2700 bucks, 110 hp combine engine...
Edited by JC(WI) - 15 Aug 2018 at 7:00pm
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:47pm
That engine on the auction prolly was on a irrigation pump or generator originally, has SAE bell housing,
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 7:04pm
engine sold for $750.
Barnabas, just take the head off and see how bad it really is stuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 8:47pm
Yes - that's the next step.   Haven't got to it yet - but I was tempted by a higher hp engine if it was a drop in and cheap. D19 was in great shape until it didn't start one spring. I'm not sure why everyone is saying the 180 gas engine with the same displacement won't work, but I trust you guys.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 9:19pm
The 180 engine (gas or diesel) has the hydraulic pump driven off the front timing gear - there is no room for it in the D19 frame.  Basically, the bottom end of the 301 engine is wider than the 262.  Having the steering shaft running along the inside frame rail of the D19 is another limiting factor.  180s had fully hydrostatic power steering - no steering shaft interfere with anything.
You are not the first person to suggest this swap.  It has been discussed many times here over the years.  It just can't be done without major surgery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 10:16pm
DWeries4 - that makes sense. It's been a long time since I've been on the site.   Was here a lot when I got started. Kids grew up and moved out, sold the horses, and now the tractors suffer more from neglect than use.   Need to fix up, probably to sell this time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 7:37am
JC (WI)   I'd like to see how they did the power steering on that tractor. There's not enough room for the steering cylinder to clear the engine on the right side, so how did they do it ??   Looking closer, it appears to have a 190 front axle with the steering cylinder inside the axle frame, so there must be an orbitrol connected to the steering wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 10:32am
Dr. Allis, if you look real close, I believe they used the 190 frame in it up to the radiator shroud and used the D19 frame forward. They used the 190 front axle assembly and D19 front casting.  And you can see the hydraulic hoses by the starter coming down  for the steer cylinder.  Does look good in the picture.
 Wonder if they had used the D19 elbow or the origional 190 turbo elbow.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 1:59pm
D-19 has a 262, 180 gas has a 265.  The 265 (2500)is the same engine family as the 301(2800 or 2900).
Life is simpler when you plow around the stump.
This page was generated in 0.118 seconds.
