7010 Engine Surge? |
Post Reply ![]() |
Roscoe62 ![]() Silver Level ![]() Joined: 22 Aug 2014 Location: Louisville Points: 145 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Aug 2018 at 3:38pm |
My 7010PD (with an L-Combine Simms Injection Pump) started surging today. I am a novice with Diesel engines. Any common issues that cause this? It is really noticeable at low to mid RPM with the tractor stopped ( no engine load) I just replaced the fuel filter and installed a new turbo. The air filter looks ok and I cleaned it out about 10 engine hrs ago. It does not overheat and I can see any thing out of order. I put the turbo and new filter on at 5100 engine hours and it has 5120 hours now. Thanks, Roscoe.
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
I have a 426 On Highway Spec engine with a Simms pump in my 220. It will surge at a slow idle. Crack the throttle a little and it smooths out. I'm sure it's the governor.
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 962 |
I've got a 7000 that runs with a lope at low rpm but it has almost double the hours. So that could be expected?
At 5000 hours it should still run smooth. I would suspect the governor...check valve...fuel line...hose clamp..or any fitting in-between. Does everything look clean? |
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
The Simms pump on a combine would about shake the combine apart. MACK
I will check all the fittings this morning. The #1 outlet fitting on the pump does look wet.
This surging is new, it just started, so this is not normal. But most likely a pump or fuel problem, and not a turbo or air problem? Thanks! Roscoe. |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8334 |
Get it all rebuilt ! No problems then
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8605 |
Govenors in Simms pumps are known to wear and cause issues like you describe. My 545B loader w/301 has it and surges at idle. If you ever seen the govenor you'd just shake your head.
Post Reply ![]() |
