sediment bowl
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: sediment bowl
    Posted: 10 Aug 2018 at 9:19pm
Who sells the best sediment bowl assembly for a CA and WD45? I bought one at a farm supply store for my WD45 and it leaked badly from the petcock even after I tightened the packing nut. It was made in China. I put the old one back on, even though the petcock knob was gone and you have to use pliers to close it. Is there a good US made sediment bowl assembly sold anywhere?
Edited by rustyorange45 - 10 Aug 2018 at 9:20pm
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 9:44pm
I think they are most all made in China anymore, I did ask NAPA one day on something different for one of my tractors, I wanted American made (what ever it was) and they got me one, a little more expensive, but it had more weight to it. you might ask your local supplier (like auto zone/Napa/Orielly's) about them that way. i'd take the one back and tell them it leaks.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 11:20pm
tryed some of them junk ones also' went to JD' got one with a long bowl on it like for a jd a i put on the b tractor an it works fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2018 at 6:04am
I've got a box of old ones... 'rob Peter to pay Paul', so far so good cause I refuse to give TSC 38 Canucks for the Chinese Krap ! Try replacing the packing with new O-ring or few turns of teflon tape ?
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2018 at 8:15am
FWIW, I was in NAPA the other day and noticed a rack with an assortment of sediment bowl assemblies. One looked similar to the one on the D15, so I picked it up, turned it over and it listed all the tractors it would fit, including the D15. It looked like a perfect match. Even the screen looked the same. $29.90 as I recall.
Left NAPA and went to Orschlens for something else and near the section selling hitch pins was also a rack with sediment bowl assemblies. These were some generic looking things with no model fits listed on them. I took them to be crapola junk from China.
If I was looking for a sediment bowl, I'd take a chance on the ones from NAPA. Looked to be the same thing I'd expect to get from DJ's, Steiners, etc.
Again, FWIW.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2018 at 8:31am
If the sediment bulb assembly gives me trouble I usually just do away with it and put in an inline cutoff and an inline filter.And no I have never had any problem
with an inline filter unless 1)its stopped up or 2)water in the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2018 at 8:32am
 Don't know where that type came from.
This page was generated in 0.140 seconds.
