Gleaner cornhead deck plates
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner cornhead deck plates
    Posted: 09 Aug 2018 at 7:17pm
We run a 430 Black head on the F2 and have NEVER done anything as far as adjusting or,heaven forbid,replace them. Would someone be willing to share any info as to adjustment/setting for a particular "ear" size and what is the criteria pertaining to completely shot?? Thanks,trying to eliminate as much "butt shelling" as possible.
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 9:45pm
I found the Corn Heads Operator's Manual for the Adjustable Row corn heads to have all the information I needed when I ran my A330 for the first time 3 years ago. Plenty of them on eBay.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 2:29am
Kroil from Kano Labs and an air hammer will get the bolts turning without using the torch.
Basically you adjust for stalk size, as narrow as possible without impeding feeding. try to have the back open slightly more than the front so nub ears and stalks can get pulled down into the rolls rather than hung up at the back of the slot.
You want the deck plates to be square, if the edge is getting rounded out it will try to pull small ears through.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 8:17am
Aren't they rounded from new? 3/8" or 7/16" round rod welded to the plate.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 9:04am
Yes Lonn.They have round stock welded to edge. I try to drive fast enough to keep the plates full of incoming.Helps move the shelled corn into head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 6:30pm
Steve,that makes sense unless there is too much "fodder" to put on the raddle ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 11:09pm
I guess I should re-phrase, The deck plates need to be straight front to back, they usually egg out where most of the material goes through.
Also, in case I left it vague, the bolts I referred to are the deck plate adjusting bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2018 at 6:17am
Deck plates need to be straight (not worn), yes. But, they need to be adjusted to 1/8" WIDER at the rear for best performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 2:23pm
the raddle isn't where you have trouble, it's too much trash on the walkers will walk corn right out the back.When you see kernals two rows over,it's coming from the chopper.
Edited by SteveM C/IL - 14 Aug 2018 at 2:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 6:18pm
Thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 9:54am
Black corn heads had 2 versions - one had a non spiral flute just behind the auger points and the late series had spiral flutes that replaced the non spiral version. The later were 100% better.   The black heads will benefit from snapping roll trimming just like the later Hugger heads.  Trim back the blade next to the spiral flute down to the angle if so equipped back about 4 " . This will allow the stalk to get further back before being pulled down.   This Hugger/3000 modification was in a service /  performance bulleting from Gleaner.
