160 gas engine head gasket needed
Hyperpack View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hyperpack Quote  Post ReplyReply Direct Link To This Post Topic: 160 gas engine head gasket needed
    Posted: 02 Aug 2018 at 5:58pm
I need a head gasket for my H3 dozer with the 160 engine. One parts store in town cant get one, the other has to order from the factory. They claim the 149 and 160 have the same gasket, I thought the 160 had a few more headbolts. If someone has a gasket or part no. I would like to get the right one the first time.
Thanks
Hyperpack
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2018 at 6:34pm
Hyperpack:  Have this to offer:  When I did my 615 engine - G 160 block  top half I purchased  a Gasket set:
Clevite VGS 6677
This included the following:
1 cylinder head gasket
1 Intake and Exhaust manifold gasket
1 Thermostat Housing Gasket
1 Thermostat Housing Seal
1 Valve Cover Gasket
4 Valve Cover Grommets or Push Rod Cover
The Gasket  kit list the following applications:
Allis Chalmers 4 - G138, G139, G149 and G160
Obtained through NAPA - did not write down the price.
All the best!
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2018 at 7:40pm
Make sure it has the fire ring on it. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 7:15am
Just use a 149 gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 10:25am
X2.    That’s what I used on the turbocharged D15 series II (160) engine that I had been running. I only had one blow in nearly 20 years of pulling with it.
