226 Crank Cap Specs
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: 226 Crank Cap Specs
    Posted: 15 Jul 2010 at 5:10pm
I need the torque specs and order to torque my main caps....had to loosen then up to free things up to change out the rear main seal...pretty easy after that. Just need to tighten things back up....also the torque specs for the pan gaskets if there are any.....thanks ahead of time.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 7:26pm
My I&T manuel says 85 ft lbs , I dont know if its any different for used bearings.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 7:31pm
The torque would be the same, no matter the bearing.
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 7:50pm
what about pattern to torque them in?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 9:33pm
Torque starting in the center and alternate side to side until you reach each end.
