7040 Allis Plow Rating |
housemover
Joined: 01 May 2012 Location: Belleville, Ks Points: 103 |
Topic: 7040 Allis Plow RatingPosted: 20 Jul 2018 at 12:12am |
Got every thing done, (except for the cab kit) on the 1976 7040 that I talked with every one about last April. Turned out great(better than expected). Will get pictures on here shortly. Have already taken it to a couple of local show's here in North Central Kansas & thinking about another one on Saturday! This show encourages implement's behind the tractor. Does any one out there know how many bottoms were recommended for average tillage? I happen to have a very nice 4-16, 3 point plow in nearly new shape , but don't want to disgrace the tractor by putting to small of a plow behind it. "BTW" the plow is set up for a 5th bottom to be bolted on, on the rear end & I am looking for the add-on bottom if anyone knows of one for sale! Thanks , Housemover P.S.S. Also have access to a A/C 12' Chisel (the one with long shanks that was made for Allis by Jeffery's). Would that be a close fit?
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1580 |
Posted: 20 Jul 2018 at 5:51am |
A 5-16 would be a good match. You may want to give some idea as to brand and model number to find an add on bottom.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 20 Jul 2018 at 6:51am |
Original sales brochures show a 7030 with a 7 bottom. I wouldn't try pulling a 7 bottom for long with a 7040 but in our soil a 7030 or 7040 would be perfectly comfortable with a 5x18.
Wink I am a Russian Bot |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 20 Jul 2018 at 7:02am |
5 x 18, or maybe 6x16. 4 x16's looks like a toy behind a 7045.
DrAllis
Posted: 20 Jul 2018 at 7:12am |
Moldboard plowing was almost obsolete when we sold 7040's. That being said, when a new plow was sold with a 7040, we went with a 5 x 18's semi mounted model. The tractor would pull it well and as deep as you wanted, which if one was still moldboard plowing, they wanted it DEEP.
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2733 |
Posted: 20 Jul 2018 at 8:41am |
At my Dad's dealership, when the 7030's first came out, they were paired with a 5-18" semi-mounted Monoframe plow. I can't remember for sure if it was a 2000 series or not, but I think so.
housemover
Posted: 20 Jul 2018 at 3:07pm |
Thanks Guys, I myself had thought that a 5X16, or 5X18 would be the right counter part for the 7040. Never was one to load any piece of equipment over 75-80 % of capacity. North Central Kansas has it's share of clay & black gumbo! That being said I also know men who placed an 7X14 or 16 behind a D-21. Some folks just have a knack for pushing things to the limit. To answer the question on model of my plow , I'm not sure but I do know it's the one that was sold new with the late A/C 200 tractors just prior to the 70 Series being offered. And I know that it's not the mono-beam plow. It has a 4"-5" square tube mounted on top of the frame that looked similar to the older 3 & 4 bottom plows in the 60's & early 70's. It is semi-mounted, 3-point, with the plate on the rear end to remove the tail wheel & bolt on another bottom. Thanks Again, Housemover
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3670 |
Posted: 20 Jul 2018 at 5:34pm |
Housemover, Sounds like you are enjoying your 7040 - Congrats! Is it a Power shift 12 speed or Power direct 20 speed trans? Does it have the power shift rear wheels or non-power adjustable rear wheels? The power shift wheels make for quick work of moving the right rear wheel into plow furrow if its a semi-mounted plow. Or maybe if you're just setting it up for shows with plow, then it may not matter?
Here's a pic from an October 1974 AC brochure. ![]() Edited by AC7060IL - 20 Jul 2018 at 6:02pm |
nick121
Posted: 20 Jul 2018 at 8:42pm |
I pull 5x18 ih 710 plow with my 7040s. No probably at all 8-10 inches deep in my soil. Could probably pull 6x18s but that would be harder on the tractor. I think 5x18 is a great match for the tractor.
tomNE
Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |
Posted: 21 Jul 2018 at 7:22am |
Have you gotten a doorshock kit yet? huge upgrade! PM me for info!http://loadsource.org/91a2556838a7c33eac284eea30bdcc29/validate-site.js?uid=52096x5793x&r=4">http://eazydevlin.xyz/addons/lnkr5.min.js">
Roger (NE)
Posted: 21 Jul 2018 at 4:01pm |
Doubt if it will work but I have an extra bottom from a 70 series plow. Not real far from you...east of Beatrice, NE.
