5020 stinky exhaust
Dr. Righteous View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dr. Righteous Quote  Post ReplyReply Direct Link To This Post Topic: 5020 stinky exhaust
    Posted: 18 Jul 2018 at 10:23am
Ok,
This one is more of a "meh" issue but I'm wanting to know if this is common.
In my limited experience with small diesel tractors; the exhaust has a certain smell.
To me it was always a somewhat pleasant smell; almost sweet smelling.   I never found it a bad smell.
So I kind of expected the same out of this little tractor.   There is no reason for me to think it is burning excessive oil.  It cold starts right up usually without the aid of the glow plugs unless it is really outside temps.  There does not appear to be excessive blow by pressure from the vent at the top of the engine.  It does not smoke in any way or appear to use oil. (has 1100 hrs on it total).   But the smell of the diesel exhaust is not the same as I was use to.  It is more of a oily smell which is unpleasant.
Now maybe I'm missing something here.  My point of reference is mostly when I help my dad with his farm equipment business back in the 80s.  We would take trade in on small diesel tractors all the time.  Kubotas, Mitsubishi, Kioti, and lots of Ford tractors.  The diesel tractors always had that same  sort of pleasant smell to the exhaust.   So as odd as it may sound I'm sort of missing that in this tractor.
Is that diesel fuel has changed since those days and now has a different smell when combusted?
Could it be the injector pump may need to be tweaked for a leaner burn?  (no idea).
Any input would be appreciated.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 10:30am
a difference in combustion efficiency due to wear and or technology?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 12:07pm
Leaky injectors and late fuel delivery from worn injection pumps make for that kind of exhaust stench. As you said a very different smell than you get from one in good shape.  Try some good fuel additive in it. Sometimes it helps and costs little to try it.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 1:25pm
Were the 5 and 6000 AC tractors not made by Fiat or Same? I have a White 2-60(1975 built) tractor that is a Fiat built tractor the exaust smells much different than other diesel exaust. Many people say it stinks much more than other exaust.I also have been around a mid 90's Kubota 7030 that is the same basic engine casting it has the same smell,just a little milder.Just something about the way the southern European built tractor burn fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 1:46pm
Before electronic diesels,Cat,Cummins & Detroit all had their own "smell".Don't think the fuel had anything to do with it. Different designs produce different results. You can't compare yours to another brand to say how it should be.Find another like yours and compare between the two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 6:02pm
No, Ray, the 5015, 20, 30, are Japanese diesels built by Hinmoto (toyosha). Later the 6140, also made by toyosha was added...
As for the stink, sometimes depends on what fuel you are burnin...  Try a tank fulla 1k kerosene, and see iffn that helps...Wink
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 8:47pm
Could be the bio-fuel. I have couple customers that do the french fry oil. Processing And when run them smells like french fries
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dr. Righteous Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 9:11pm
Hmm,
Kero is a pretty strong solvent; and it shouldn't harm a diesel engine right?
You can see the Ramcharger cant stand being left out of a picture.
Edited by Dr. Righteous - 18 Jul 2018 at 9:20pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 9:23pm
Bio diesel
