WD45 carb issue
Moegs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moegs Quote  Post ReplyReply Direct Link To This Post Topic: WD45 carb issue
    Posted: 16 Jul 2018 at 1:06pm
My 1953 WD45 with the Marvel-Schebler carb only runs on partial choke.  Full opening the choke kills the engine.  Runs just great on the partial choke. Mowed my pasture this way.   Full choke also kiills engine, (obviously).  Suggestions?
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 1:14pm
Partial plugged fuel screen/ filter.
Screen is on top of sediment bowl or up in the valve housing above the bowl.
Edited by Jim Hancock - 16 Jul 2018 at 1:24pm
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 1:15pm
Open the main jet a turn or two for starters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 3:44pm
The engine is running lean. When you flip the choke partially on, it fattens the mix bringing the engine back where it likes the mix to be and it runs. Probably took on some dirt in either the idle circuit or enrichment circuits which cut the fuel mix and leaned the engine out. Its time to start at the tank and go through you're whole fuel delivery system and clean things up including the Carburetor....
Steve@B&B
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 4:11pm
I agree 100% with steve.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 6:29am
Steve Said it. Possible clogged up around the main jet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moegs Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 11:44am
thanks for all the tips!  Will let you know what I find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moegs Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2018 at 1:09pm
Ok.  I have gone through the entire fuel system and cleaned the carb 3 times.  I ran carb cleaner needles through all the jets and soaked in gumout, blew out with comp. air.  No luck.  Won't idle.  Have to finesse tne power valve along with the idle mixture screw to get some decent running but still does not sound right.  No throttle response.  Still have to partially apply choke to get it running the way it should.  I did notice the idle jet is somehat buggered up like someone tried to remove it.  Ouch
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2018 at 1:22pm
Check the float level too. Also for any manifold leaks. Since the jet is bunged up someone probably tried to fix something in the past.
This page was generated in 0.049 seconds.
