planter plates for popcorn
farmerzzz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmerzzz Quote  Post ReplyReply Direct Link To This Post Topic: planter plates for popcorn
    Posted: 03 Jul 2018 at 4:08pm
Can I use sorghum plates without spacer to plant popcorn? What do the rest of you use, I can not get my pop low enough with my corn plates. Are there special popcorn plates?
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2018 at 5:02pm
Are you talking an air champ or a plate planter?
WD D17D 170 190xt 190xtIII 200 7020
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2018 at 5:13pm
E&R seeds in Monroe,Indiana has all kind of plates. Old Order outfit so communication is a little slow. Got the popcorn plates for my IH 56 there.
Edited by exSW - 03 Jul 2018 at 5:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2018 at 10:00pm
I've always used corn plates, have used both 16 cell and 24 cell.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 8:24am
I only plant one row of popcorn so I use the sweet pea plate and put duct tape over every other hole. Popcorn plates are avaliable for my Earthway planter but I haven't ordered them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmerzzz Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 8:29am
I have a 500 AC plate planter and I have been using corn plates ,but my population is always to high! What size plate did you use?
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 9:20am
I was sorting thru some plates I picked up at an auction and found a pair that are listed in the planter book with #302610 **;
** needs the 327117 filler plates for corn hoppers
?What are some good numbers for sweet corn size range??
Edited by JoeO(C-MO) - 23 Jan 2019 at 9:47am
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 12:56pm
Plate sizes will depend upon your specific seed, can't give exact #'s. You will have to get seed, test fit seed in different plates until you find one that looks good, then set planter , and do test pull on hard ground. I plant same sweet corn every year and have to use different plates every year due to seed size being a bit different.
You might try blocking off some of the plate holes and test drop from there. I have had to do that a time or two!
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 2:22pm
Our neighbor planted pop corn with a 494a JD planter and Sorgrum plates. It had a hill drop setting on it and he used that.
tomNE View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 6:25pm
a company in lincoln NE makes/has new planter plates for whatever is needed.  google them up!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2019 at 8:54pm
THATS LINCOLN AG PRODUCTS - Lincoln Ne.   any yes you must use filler plate with the AC plates or the universal plate (some refer to them as JD plates because they fit Deere w/o adapter drives like Ac and others had to have)  .    https://lincolnagproducts.com/
The spacing will be just like field corn on the chart in the op man.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2019 at 6:59pm
Planter Plate
