Front rim width
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Front rim width
    Posted: 20 Jun 2018 at 9:28pm
I am looking to put wider tires on the front of my 185 (I currently have tiny 7.50 x 16).  I plan on using the 9.5 x 15 tires that most of these tractors came with.  What size of rim do I need and how do I get the correct offset?
Many thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 10:55pm
exchange the wheels and tires off a wagon. if you don't have a wagon, watch sales, you can usually buy the whole wagon with the size tires/wheels you want cheaper than buying just tires/wheels out right. gravity flow wagons with the 6 bolt pattern will fit right on. and you can usually buy them for about $300. or so, and still have the wagon to use. I blew a wheel on the front of my backhoe, and a tire/wheel off one of my heavy gravity flow wagons fits right on the backhoe. it was an 8 bolt pattern. and I've got the rear tires/wheels off my IH rotary combine on the front of one of my tractors, also 8 bolt pattern. some/most Chevy pickup 6 bolt wheels will also fit the front of the tractors. that's why sometimes you see fancy wheels on the front of tractors, they are from the kid's pickup!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 4:53am
If its a 6 on 6" bolt pattern, its almost a universal fit tractor front wheel.  6" wide will do a 9.5" tire.  5.5" rim will also work, but will squeeze the tire a little taller...Wink
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2018 at 6:53am
Recommended rim with for 9.5L-15 tire is 8.00 in. per the firestone tire book. Most likely will need a 5/8 or 3/4 offset.
The 7.50-16 would normally be a 5.5 in width.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 7:28pm
8" is standard for the 185, if I had to buy rims, I would go for 10" rims and use 11L-15's. I have 11L -15 4 rib fire stones on mine with 30" rears and it sits about level. I used the stock 8" rims and is bulged in the center a bit.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2018 at 10:25pm
D -- do you have a loader on the front? If so please find a salvage lot that has a tractor like yours. The rims on the front of a tractor have heavier centers in them than wagon rims. For years I had to get them from the JD dealer, strip the paint, and repaint them white.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2018 at 12:29am
I used rims off a New Holland round baler to put wide tires (12.5 X 15) on the front of my Oliver 1365 with a loader.They had the right offset and they are a lot heavier rim than
most implement rims.Been on the tractor several years with no problems.
