REPLACING THE RUBBER CAB SHOCK MOUNTS ON 7060
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: REPLACING THE RUBBER CAB SHOCK MOUNTS ON 7060
    Posted: 17 Jun 2018 at 1:55pm
HELLO
 INFO NEEDED, LOOKING TO REPLACE THE CAB RUBBER SHOCK BUSHINGS ON THE REAR AXLE  MOUNTS ON MY 7060, WONDERING HOW TO DO IT ,HOW HARD IT IS AND WHERE DO TO GET THEM?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 9:26pm
Do you have them out yet? if not take some pictures installed and get some dimensions when out. Never know we might be able to find something that was close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2018 at 9:32pm
Remove nut from 5/8 bolt, remove big nut, lift back of cab, remove four bolts from side of cab. Remove old mount and install new mounts.
Agco dealer is only place I know of for cab mounts.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 4:45pm
THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 6:59pm
If they have a name on them there is a chance I might find some. Pictures and dimensions and or a part number on them might help too.
