spin out wheels
TL12A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12A Quote  Post ReplyReply Direct Link To This Post Topic: spin out wheels
    Posted: 13 Jun 2018 at 4:57pm
Could someone please explain how to use spin out wheels? TIA
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 5:03pm
Sounds like you need an operators manual. How rusty is the hardware? How long since the wheels were moved?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 5:06pm
And what model tractor do you have? Different models use different style locks
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 5:12pm
If they haven't been moved in years you'll need a big hammer,bigger hammer,giant hammer,torch
and a good supply of cuss words that'll get you started anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 5:36pm
Then you get them to adjust the first time won't lock down from then on. Work sorta like cast spoke truck wheels, wedges lock centers to spin rails.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 5:41pm
Here's a start...
[TUBE]l2qXT3GGc5w[/TUBE]
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 8:18pm
Lots of PB Blaster liberally applied multiple times and a real strong (1") air wrench!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 11:01pm
Remove the wheel lock.  It is bolted thru one of the slide bars usually behind an eccentric.  Then loosen the four eccentrics.  Then get on and drive it forward or backward to get the wheel where you want it.  If I remember right, I had to jerk the tractor to get it to move.  Two people would be ideal, one on the tractor and you watching the wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 4:37am
Once the clamps are loose, and the stop removed, step on the opposite brake, of the wheel you want to move, and pop the clutch in a jerky motion, one wheel will move out, in fwd, and one will move out in rev...Wink
Edited by DiyDave - 14 Jun 2018 at 4:39am
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 6:17am
Sounds like you're spinning both at same time. I guess that's possible, but never tried it. I only spin one tire at a time. So everything you said, except I'll add a slight lift to the tire that Im spinning in/out, using a hydraulic jack placed under the tractor's rear drawbar slide frame.
Edited by AC7060IL - 14 Jun 2018 at 6:22am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 7:05am
Brakes got to be fairly good for that to work but I've done it many times that way.
Oh, are you saying they are being moved at the exact same time? Nope that can't be done. You step on one brake and move the opposite wheel then step on the other brake and move the wheel opposite that brake and then tighten clamps and install stops. That's how I do it.
Edited by Lonn - 14 Jun 2018 at 7:09am
Wink
I am a Russian Bot
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 7:11am
There's a youtube video that shows how to work the spin outs....
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2018 at 7:50am
Go to 6:15 to see how they work
[TUBE]cYH3q9nJ-fc[/TUBE]
Wink
I am a Russian Bot
