WD Cab Heat/ Thermo Bypass
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Topic: WD Cab Heat/ Thermo Bypass
    Posted: 13 Jun 2018 at 8:20am
Where do you hook up a cab heater on a WD engine?
I'm trying to figure out how to install a heater into a WD Cab.
Best I recall you could hook up to the Thermostat bypass on a 45, but I don't see one one this engine.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 8:28am
you need this style of thermostat housing.  you may have an old style
Edited by CAL(KS) - 13 Jun 2018 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 11:31am
yes, that's what I thought....
Guess I gotta order one.   Will the WD45 thermostat bypass cover fit the WD?
I see them on Steiner, but not for WD.
Edited by corbinstein - 13 Jun 2018 at 11:37am
This page was generated in 0.172 seconds.
