190 Gas - fuel pump rebuild
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: 190 Gas - fuel pump rebuild
    Posted: 04 Jun 2018 at 4:34pm
Friend of mine has a 190 gas, looking for a fuel pump rebuild kit, can't seem to find one. Anyone know of a supplier?
cheers,
Creek
Have spacesuit, will travel
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 4:58pm
No, but he could send it to Hite Parts Exchange in Columbus, OH to have it rebuilt.
dhs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhs Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 6:18pm
Hopefully this information is not outdated:
Thank you for your inquiry. Yes, we have a kit for your Carter fuel pump. It would use our number "CK-4220". The cost is $47.50 plus S&H. I have attached a picture of the kit to this email so you can see what parts come with it. If you'd like to order it, please call the store at 781-335-8860 anytime between 8 am and 5 pm M-F. When you call, ask for Ted, and give him the part number above.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 7:38pm
I had that problem with my gas 4020 years ago. I didn't like the price for the Deere replacement pump, so I went to an electric pump. I made a plate to cover the hole in the block for the original camshaft driven pump that was adding gasoline to the oil and bolted the electric pump to that plate. I wired it to run all the time the ignition switch was on. It worked much better than the mechanical pump when the tractor had been sitting long enough for the gas in the carburetor to have evaporated. New starting procedure, turn on the ignition switch and listen for the electric pump to run and then get quiet. Then pull on the choke and start cranking with the starter and got nearly instant running, no cranking the engine to get the mechanical pump to refill the carburetor. I think the pump I bought was from NAPA in their old store in Story City, now a thrift shop with NAPA in a new store nearly two blocks south of that location.
Gerald J.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 7:39pm
The number 781-335-8860 was good the last time i called them. and at that time S&H was $8.50.
 There are electric fuel pumps on ebay for cheap too....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 11:01pm
I have electric pumps on all my last 5-6 combines, both gas and diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 9:10am
Crap I should have thought of the electric fuel pump fix, that might be the way to go. His 190 has low hours but starts hard, switching to an electric pump might solve two problems. Or he could try to buy the repair kit first, it might be that the existing pump was bad from the start. Thanks guys.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 6:27pm
I was just quoted $185 for Hite to rebuild a core I picked up at a salvage yard FYI.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2018 at 7:10pm
I think Mike Fahrendorf (Skyhighballoon(MO) had a post about pumps you could buy and take the parts out and put in the AC pumps to rebuild them. He has not been on in over a year hope he is ok
