Starter sparking
Allis Wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Starter sparking
    Posted: 27 May 2018 at 12:29am
When I pull the starter rod on my wd45 the connection where the hot wire goes into the starter switch sparks until I release the rod what is the problem here? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 4:43am
Likely a loose connection has degraded to the point where you will have to replace the solenoid switch, on the starter.  Might also be that internal resistance, on the starter has risen to the point that the starter needs an overhaul...
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 6:31am
Try taking the pull switch off and polishing everything up and reassemble.  Make sure all connections are clean and tight.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 8:02am
The insulators may be missing.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 8:46am
Usually, what happens is the square contact on the switch side is worn or burnt to where good contact with the Starter pad is starting to be a problem. This is a high amperage point, and good solid contact is important to transfer high current to the Starter motor to engage it. If that's the case, a fireworks show is usually the norm as you have. Sometimes if the square contact isn't to worn, it can be cleaned up or rotated to the better area on the contact. If its pretty much toast, you have two ways to go with it. Either replace the mechanical Starter switch with a good USA made unit, or move to a Starter Solenoid either key crank actuated or button. If you move in that direction, the Starter motor contact pad will have to be changed to a stud to accomodate the Starter relay which can be mounted right on the Starter motor. This means you need to go into the Starter to make the change-over. Its a little more work, but that's really the way to fly from a reliability standpoint. We still have  quality USA made switches in stock if interested if just changing over the switch is what you rather do. We offer Starter motor services also....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 11:12am
MACK where are the insulators? I think I’m going to pull the switch off and clean it up good and try that. Where do you get a good solenoid switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 3:29pm
This is what the switch looks like is there a problem here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 5:26pm
Ya think?  I say yes!
At the bare minimum, the contact on the starter needs a good filing, get it down to clean copper, and put a new switch on, or upgrade, as steve says...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 6:54pm
Ok thanks I think I’ll order a new switch and clean the contact up on the starter. I want to keep the original starter rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 6:56pm
Could this have anything to do with using a 6v starter on a 12v system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 7:47pm
No, actually it is easier on the switch.  But you need to clean that one up REALLY GOOD, or get a NEW one.  You file the opposing pieces so that they can make TOTAL contact against each other when you pull the rod.  You can use a piece of copying paper between the switch pieces to see how much you need to file and how good they fit against each other.  Clear as mud??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 11:23pm
Yep Clear as mud. I ordered a new switch tonight I’ll just clean up the post on the starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 4:43am
A few other things that can cause that damage, are continuously trying to start with a weak battery, bad connections, or too skinny battery cables.  I like that carbon paper idea, to check the fit, could also use machinist's blueing...Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 1:51pm
Thanks guys I got a new starter switch and it works like a dream now.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2018 at 3:22pm
good for another 60 years
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2018 at 1:11am
Stan R I hope so it probably is
