Disc / Field cultivator size for 6080
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Topic: Disc / Field cultivator size for 6080
    Posted: 18 May 2018 at 10:03pm
I realize this question has a lot of variables, but what size Disc and (1200) field cultivator does everyone run or recommend for a 6080? Assuming 2wd and moderate / decent 34" tires with some added weight. Adverse conditions with quite a bit of heavy wet clay soil. I don't want to work it too hard and want long engine/power train life. I think I'd rather have a little smaller and be able to run faster than the other way around...
Is a 12-15' disc about right?
Does a 1200 field cultivator with buster bars pull harder than a disc or is 12-15' good for the field cultivator as well?
Thank you for the advice!
Peter
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 7:52am
The disc is something that you DO NOT WANT TO GO FASTER WITH. The weight of discs vary so much it’s hard to give you a width. A good Sunflower disc 10 foot would be a workout.   My 6080 struggles with my 22 foot Sunflower with the wings up. Flimsy disc who knows 14-15 foot.   Field cultivator that 12-15 range.
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 5:58pm
I pull a 18 ft 1200 field cultivator with a 190xt and a 14 ft 2300 disc.
WD D17D 170 190xt 190xtIII 200 7020
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 8:27pm
I've pulled an 18' Case-IH 475 with 7.5" spacing with Dad's 6080 in med. 3rd. Was dualed up, pulled it good, probably could have used 4th gear.
